I was wondering if someone can help me identify the following component:
Not much to go on by the picture I know, but one side of it has blown off so I can't make out the markings on it.
One side does however read. F1J
I'm guessing it's a fuse resistor, possibly 0.1 ohm?
It's out of a blown PSU for a PC, but the PSU is a mini proprietary type for a Sony Vaio all in one computer, which are basically impossible to replace, as no where stocks the PSUs, and it seems such a waste.
I'm hoping just replacing this will fix the issue and it's not connected to some sort of short. Doing some research on these, appear to show that these PSU's failure rate was quite high, and no doubt all the same issue.
Thanks.
Thanks.
If the resistor has blown then there has to be a reason. Its highly unlikely it just blew up for no reason. Something is forcing too high a voltage into it. So there is another problem elsewhere.
You could use an external supply and feed the various voltages into the computer via short wires as a last resort.
I came across the following when researching reasons for something like this to happen.
So I guess I'll need to test the caps first, failing that presume it was a power surge or lightning strike?
"Supply dead, fuse blown - shorted switchmode power transistor and other semiconductors, open fusable resistors, other bad parts. Note: actual cause of failure may be power surge/brownout/lightning strikes, random failure, or primary side electrolytic capacitor(s) with greatly reduced capacity or entirely open - test them before powering up the repaired unit."
Sorry to resurrect but this item has remained in my attic for ages now.
Just wondering how I might be able to source a replacement component? I'm not able to identify exactly what it is other than the info I first supplied.
I agree the fault is likely to be something else, but it is possible that it could be power surge related.
I've read many people binning these PSU's because of failure and because they were of a design that a standard psu couldn't replace due to size constraints.
So I'd like to repair this one and get the PC working again.
