F.S.: Isolating transformer 3kVA (!)
FS: Isolating transformer 3000VA, prim:230V sec:2x 115V
NOS
see pics
Weight: ca. 15-20kg (!)
Price: 200€
In my country they changed the nominal mains voltage from 220 to 230 a few years ago. The transformer is older. The actual voltage is usually around 225 volts. If you put 230 prim on the transformer, you get sec 2x 115 volts out. No need to worry that the transformer will be damaged.
