Hello All. I have a few things I am getting rid of due to limited space in my house. I will list the things I am selling:
1. A new pair of Sliver flutes 8 inch 8 ohm drivers.
2. A Heath kit model 10-102-138 ( I have no Idea if it works)?
3. Dec Power Supply Model H739 ( I have no Idea if it works)?
4. I have a box with nothing on it. I was told it was a frequency testers for running sound waves thru speakers to test them. ( I have no idea if it works)?
The Following two sets of woofers need to be re-foamed.
5. 8 Inch Pyle Driver model ( W8C200-F) I did run sound thru them and I heard no rubbing of the voice coil.
6. I have 2 poly woofers with the label of made in Denmark and it has a G-17 orange Sticker on both drivers. I did the same to these drivers as the ones above.
7. I have two 10 inch poly woofers that the foam is in great shape and I did test them and they sounded fine. I know they are (DVC) woofers. One of the woofer has a small tear on one of the surrounds but, it can be easy glued to fix it.
8. I have a old pair of polk Audio tweeters. They do work and they have some dust on the domes.
I am willing to get rid of all of this for $100.00 and local pick up is in Plymouth Michigan. Here are some pictures. Thanks Mr Daniel
