ExtremA, class-A strikes back?
Mike,
It IS dC offset protection. Whether the offset is 3V or 12V is moot.
No, no, I think we both got a different interpretation of the terminology. A DC protection will prevent the load from ever seeing DC due to various reason, ie. someone hooking up a source that outputs DC, or a short in one of the output transistors etc. A DC offset protection implies that it prevents the amplifier's offset from reaching undesired levels, regardless of the input.
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
I suspect you're confusing DC offset compensation or correction with protection.
DC protection and DC offset protection are one and the same thing.
For Mr Green,
the heatsinks for the ExtremeA, had to wait quite a bit for these to arrive.
Modular sinks, 39 extruded profiles with slots which are pressed together.
The sinks were used to cool huge IGBT's, able to deliver +250 amps each, in welding machines.
Comparable with the heatsinks used by Tom Colangelo in the Viola power amps.
These require a revamp job before mounting them inside a chassis ; a repressing of the extrusions under a professional press, grid blast, accurate grind levelling of the device mounting area and anodising.
Really heavy bricks.
Strikes back? Oh no.. evolving is the word 😉 Time to try something new now when my Zapsolutes have served me for about ten years.
I want to thank Sander for great service and for quick delivery of the PCB's.
Don't know if I should start my own building thread or not and keep this one for general info and discussion?
One Q though:
I'm about to build the ExtremaA's as separate monoblocks.
I have this idea of building the chassis the way a normal stereoamp is built iow. with one heatsink on each side of the chassi and let the circuitboard bridge the two heatsinks. The heatsinks I have may be a tad to small for one 100W channel so I was thinking that I can mount one outputpair on each sink. Then I realized that this may be a bad idea due to the possibility of a temperature difference between the two sinks which could result in a drift of DC on the output and maybe other problems.
Can someone please comment this?
Thanks in advance!
/Peter, the man formerly known as Pan but who lost his password hence the moniker Pan2
Isn't an input impedance of 2k2 a very difficult load for many preamps?
Yes, for single ended preamps, but since this amplifier is meant for balanced operation where 600-ohm impedances for preamps and line drivers are normal this isn't a problem. Hence driving this amplifier from a single ended (tube) preamplifier that normally likes to drive amplifiers with 47K ~ 100K input impedance isn't going to work well.
You have not mentioned a word about how it sounds. How about some comparisons with the sound of other amps atleast?
I'm not posting here to offer my take on something which is highly subjective, much like anything related to audio. Everybody has their own likes and dislikes regarding this, some like a fair bit of 2nd harmonic (tube sound) others like a THD raising with frequency. This amplifier comes close to the proverbial 'wire with gain' as it offers THD values, even at full output power, that rival that of the CD.
Best regards,
Sander Sassen
Peter,
You answered your own question in the last sentence 😉
Best regards,
Sander Sassen
Best regards,
Sander Sassen
I do understand the subjectivism issue. However, then what is the objective of posting here if not to motivate potential builders/buyers. The price is a little on the higher side for most diyers, though we tend to spend a lot more with various experiments on the way with each project, but my guess is that unless something is said of the sound, this will remain a project of theoretical interest for most here.
Craig405 said:
Thats a lot of transistors!
The transistor number is not an issue, and Bob Ellis can supply 547C's at a bottom rate.
Compared to exotic matched FET designs, this one gives far less hassle.
Only real hurdle to take for the ExtremeA is the heatsink requirement.
It's a real shame that designs as Bruno/Sander's ExtremeA and the ones by Glenn Kleinschmidt receive so little attention because people are scared off by a few dozen 5 cent small signal transistors.
In time i hope to get an 8 discrete opamp board fully balanced pre-amp design finished, a gift from Peter Schut, a former designer for Sphinx(subsidiary of STC) and Classé.
A pre-amp that i think would mate well with the ExtremeA.
[Siltech(STC) even used to have their own capacitors made for the amplifiers manufactured by their daughter company]
I am more inclined to think people are scared off by unpredictable sonic performance. If one is prepared to invest into heatsinks, PS and metalwork a Krell or a Pass clone guarantees some level of sonic bliss.
