I'm currently in the process of putting together a small high-ish-fi bedroom system, with a little 2 x 10 watt tripath based amp, ESP's DoZ Preamp, a cheap DVD player with an optical out and a cheap chinese DAC (the Pro707). As you can see, there's a few compromises to keep the cost down, but I've tried to create a component system so I can swap in better gear should I ever be able to afford it.
However, I'm also interested in analogue sources (it should be noted that I'm 17, so vinyl was unpopular by the time I was born), and as such, I've built a VSPS, and tested it with my parents rather ordinary Sony PS-LX43P turntable.
Obviously, though, I can't keep using that, so I was wondering if anyone could suggest a turntable (second hand is fine) available for ~$150 (in Australia, or including shipping here) that would provide sound at least as good as the long-in-the-tooth Sony. Budget is pretty inflexible, as a school student my income is limited.
DIY isn't really an option, I don't have the tools, skills, or time, and I doubt I could do it that cheap anyway.
So, to sum up - I'm after a turntable of merely acceptable quality that is available cheaply!
