I like to share what I have found.
I am experimenting with a no of speaker configuration based on MK's MLTL worksheet. The speaker config is based on
1. 1 full range driver and MLTL cabinet, the driver is
FE167E.
2. 2 way speakers using same cabinet based on Usher
8945 and 9950 tweeter. Overall efficiency is less
than 87db.
I try to match the driver to the cabinet and do the necessary tweaking to match to the cabinet. Option 1 sounds ok but really lacks the bass response and the high is not 100% satisfactory. I believe option 2 is the way to go for MLTL, it will give sufficient bass and top end.
However option 2 lacks the efficiency which FE167E provides. my next step is to use better efficiency woofer about 95 db and compatible compression driver cross around 1.5Khz, similar concept to audiokinesis speakers. I use active filter this combo will sound awesome. Overall efficiency will approach 95db.
Any comments welcomed.
FE167E.
than 87db.
