Hi Guys
Im just here for a fast question.
I have build the first part of a pa150W gainclone.
Noninverted with 20x amplification, 10k input resistance, and this little bugger.
http://img23.imageshack.us/img23/5669/dsc01243r.jpg
However, when it is mounted, the bass sems to be gone - and not out in the loudspeaker, unfortunetly.
So my question is, how can that be?
I tried just as a test to use a 1uF wima cap, it doesent sound good, but it has all the bass that the Jensen cap seems to have lost.
Hope someone can give an explanation.
FlexQ
FlexQ
Nuuk said:0.7uF is too small a value. It is obviously forming a high-pass filter with the input resistor. Try using at least 2.2uF.
With 10k input resistance it should form a highpass filter at 22Hz.
Dr.EM said:Yes, just parrallel it with your 1uF WIMA cap, should do fine
I will tryk that, will return when tested .
Btw, the cap is made for tact audio, has been sitting in the input of a pre amp at the cost of around 20.000$ .
Sadly, that means diddly-squat!
Well, it almost does .
When it has been working, i can make it working .
But testing is ongoing ,).
Right. -3 dB at 22 Hz and attenuating up to 110 Hz. Do you use Ci? Tuned to what frequency? How do those two filters add up?FlexQ said:With 10k input resistance it should form a highpass filter at 22Hz.
Maybe. What was the input resistance of that Tact Audio preamp?FlexQ said:When it has been working, i can make it working .
There was 2 flaws in my theory ;P
the first one was me thinking i knew all about that circuit, and the second that this cap is used in another type of circuit.
So right now i am using another cap
It sounds good, all three amps playing right now.
I am currently playing it up against NAD 214, and it suck quite a bit in relation to detail - but it has a tighter bass. But that could be because of that input-cap.
any suggestions to which i could use instead of?
FlexQ
EDIT: Here is what happens when one doesent have a place to work ..... dinnertable-invasion .
http://img223.imageshack.us/img223/3269/image063.jpg
And of the pride
http://img10.imageshack.us/img10/5996/image064r.jpg
analog_sa said:FlexQ
The fact that a capacitor is expensive or used in expensive equipment means very little. Is it properly broken in? Still, is it very difficult to raise the input impedance to 100k? Assuming it's a non-inverting amp.
I will try it as soon i come home .
AndrewT said:if your input impedance (Zin) is 10k then I would suggest you try >=9uF as the DC blocking cap to hear what it sounds like.
I might have one lying around, i will try it
pacificblue said:Original heatsinks.
yeah, did not have any heatsinks so i just used what i had lying around. Not quite enough, but fine for testing purposes
Does any of you have any suggestions to what type of DC blocking cap i might use?
FlexQ said:Does any of you have any suggestions to what type of DC blocking cap i might use?
That's a very risky question around here!
Other than "specific" caps, in general metallized polypropylene or MKP seem to be preferred.
Brainfart ... just sat at my desk at work, and suddenly i realised what i have been doing.
The circuit is the same. However, i didnt have any 200k resistors so i used 1k/20k to set the amplification.
But, if you use such low resistor value, it will cut way up in the middleband.
So, i got my hands on some 10k and some 200k, and my 0.7uF jensen cap suddenly worked fine .
I forgot all about the virtual ground the signal sees into from the input.
at the in+ and in- there will always be a virtual ground. So in relation to the signal the input/gain resistor has a he*k of alot to say.
So i solved my own problem, it took some time, but it came .
Now it is playing just about fantastic. So tomorrow i am going to start burnin ...
Have a nice evening guys.
an inverting topology, with negative feedback, uses the series input resistor as the Zin to the virtual earth point at the -ve input pin.
A non inverting topology has a very high input impedance and Zin is set by the resistor from +ve input to ground that carries the input offset current and allows the amp/opamp to work properly. The +ve input pin is not a virtual earth.
AndrewT said:Hi,
Exactly, and i am using the inverting input as input
- Chip Amps
- Expensive signal caps extinguish bass?
