Received this amp, completely burned down. Removed all parts, check oscilation in the tl494 .Ok.
After i installed new drivers, no more oscilation.
Pin 3 of the TL has 5V. Ground this pin, oscilation starts.
This pin is connected to a few transistors, which are going likely, to a second LM393.
Maybe somebody has a diagram?
From a recent thread:
Skar RP2000.1D Question
The SLA1500 diagram is likely close but doesn't show the protection circuit.
http://www.bcae1.com/temp/SLA1500.pdf
This is covered in section 44 of the Power supply troubleshooting page if you have the tutorial.
