The exe is just the installer, though I'm not sure why it even needs one. I'd prefer just the straight xls file. Not a bad effort, but I can't seem to move or expand the window to fill my Excel screen in 2003 (yes, a lot of people haven't upgraded). Also, I like to make my inputs and outputs different colors, say red for user input and blue for calculated outputs.
Here is the basic version Excel File with Calculators...you can also use 'Gnumeric' instead of Excel. Does not require VBA.
Click On This Link: ecalcxls.xls
Yea...
opens fine on my Mac... looks like the images are jpgs (which makes them noisy/fuzzy) gifs or png would be better.
Thanx
dave
The first two sheets I opened were not protected.
The first thing you should do is select each sheet in turn and protect it.
Then save the protected version as a spare and save again for your repeated use.
I have reformatted the Images so that they are now small GIF Files resulting in reduced overall XLS File size.
NOTICE: The reason I have not protected the Worksheets or Workbook in this Version is so that it can also be accessed with "Gnumeric" Excel compatible spreadsheet App or other similar compatible Software that might not allow protected file access. I also recommend that you protect each sheet individually and then protect the Workbook as mentioned. Also save the original as the 'Default' backup...
DOWNLOAD URL FOR ecalcxls: https://www.box.com/s/e620f13f716e307bf9d3
Electronics Calculators Excel Workbook
Thread Redirect
NOTE: This is a recent update ... all posts below are prior to it.
Thread Redirect
- Design & Build
- Software Tools
- Excel Workbook Electronics Calculators
