Exactpower EP-15A Voltage Adjustment?
I recently got one of these back up and running (replaced the group of four small caps), but the output voltage is a little high at 122-123V (instead of 120V +/- 1V).
There are three trimpots inside, and I am guessing that one or all are required to adjust the output voltage.
Before I start experimenting, does anyone know what each of these trimpots adjust?
hi baileyler, noticed you predicament concerning EP15A. I have just replaced all the capacitors on my version (230v) and have the same problem that is to say my output sits at 233.8v and I know that it can be adjusted. How did you manage to adjust yours as I would be interested to say the least ?
I have used 560uF capacitors for my replacements and the unit runs as it should exept for the o/p voltage. Any help would be gratefully recieved.
