Hi
I've seen the forum through audio searches before, and decided to join as I've a few (audio) projects on the go at the moment.
Got interested after a work colleague mentioned he was building a Douglas Self six-pack amp set up with active crossovers, so I'm currently designing a chip amp based competitor to those.
I'm not too qualified on the analogue side, but have designed / built and programmed my own MCU based systems for a while now. (5-10yrs)
Currently, I'm listening to a dual LM3886 setup in a plastic box from Maplins - I won't sully the good name of gain clones - but I'm impressed with the sound, even into car speakers mounted in makeshift plyboard cabinets. I can already hear some of you raising eyebrows or sucking air through your teeth, but this is a start, and I can at least now improve in increments...
Ttfn,
the gabbleduck
Ttfn,
the gabbleduck
Cheers and welcome aboard. Even the old stuffy dudes started somewhere.
Hi
...but I'm impressed with the sound, even into car speakers mounted in makeshift plyboard cabinets. I can already hear some of you raising eyebrows or sucking air through your teeth, but this is a start, and I can at least now improve in increments...
Ttfn,
the gabbleduck![]()
Hey - Hi!!!! And Welcome to diyAudio!!!!
Actually you have stumbled onto a leading edge - state of the art system!!!
Things can only go up from here.... and you now get to spend until forever putting up with us and our usually silly thoughts and projects...
