Eurodesk Behringer SX2442FX mixer - no output
Hi. Just got a Eurodesk Behringer SX2442FX mixer to repair. Came in the shop the other day. It has nothing coming out of the "main out" audio jacks. What could be the problem? OP amps? No history provided unfortunately. Everything else works, its just the output.
so is it the XLR's or the 1/4 inch outputs we're talking about?
the metering is ahead of the output as well as the main out inserts i was hoping to have you check those specifically.
odds are it will likely come down to bad solder joints.
quick question are your subgroups assigned?
