You said you read the previously linked thread on this, but DID you, ar did you dismiss it as not being the same as your problem. Make sure the trimpot is set for MAXIMUM resistance and RE-READ all my posts in the other thread regarding setting up.
Really, these modules are a piece of p**s to get going, and understanding how they work and following instructions carefully will make them work first time.
Cheers
Graeme
Cheers
Graeme
jacquesl said:the resone i built this amp is that someone give me a marantz amp that dont work, so i finded the fault, its the power amp section the rest work thank god.
model 1060
its has crappy old confusing parts in but if mastered it after 2 hours
Good you! My broken Marantz 1060 is on my bench for about 3 months!
That ******* old discontinued parts...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=46971
Good luck for your amps!
