Estimating Transformer Output (Amps) . . . again.
I've asked a similar question before but this time I have a little more information. Is there any way of ball-parking the output of this transformer?
It came from an active 5.1 sub so I guess it was powering multiple amplifiers.
You can *measure* it under working conditions.
Connect main winding, the 34V CT one to a large diode bridge, say a typical 35A (or so) one so it´s out of the equation, to a , say, 4700uFx50V capacitor, and measure DC voltage.
You´ll get some 48V DC.
Now load output with increasing loads (decreasing resistance).
You can make cheap disposable load resistors out of sections of nichrome heater wire,
cut to desired resistive value and attached to parallel rows screws on a piece of wood, with a bathroom tile between wire and wood so wire does not burn it.
Sort of similar to this but horizontal (easier).
Something similar to this but with wire sections in parallel.
Make each section 20 ohm, which will take 125W nominal.
They will become very hot, "shouldn´t" become red hot like these, but no big deal if they do, this is an estimation, not a *precise* measurement.
Connect 1-2-3-4 in succession in parallel , starting with one, of course, so you´ll be loading your transformer with roughly 125 - 200 - 300 W, and so on.
When DC voltage drops by 20%, so under 40V, that´s the practical limit of your transformer.
Junk the cheesy kludged load resistor, it´s served its purpose, anyway you spent 10-15 bucks-quid tops.
What´s slang for Euro?
No need to leave load ON for hours, just 1 or 2 minutes to measure DC under load for each value.
Remember to fuse transformer primary (say 5 or 6A fuse), just in case.
No, my guess is it may work then burn your house down some day....
But analytically - 17.5Vac CT will give approx +/-25Vdc - into a typical speaker (6 ohm) thats about 4Adc or about 3Aac at the secondary.
Weigh it and compare to catalog transformers.
It will certainly "work" at idle. How bad will it sag at full roar? If you get stoned and blast it all night long, will it melt and stink? Guessing through the internet is maybe the second worst way to determine tranny ability.
