BTW, dont get too nervous. I am not doing any DAC chips, or even audio/video chips now. Not involved in any audio/video/consumer designs either. I am more than happy to see finally someone would bring out something to beat out TI and ADI, in fact. 🙂
Be nice if we could get a PCB designed for this for DIY use 😀 I'm extremely interested in building a 2 channel DAC using this chip. Or even an 8 channel possibly. How do you pass DSD to the DAC anyways? Is there a firewire input capability?
Dougie085 said:Be nice if we could get a PCB designed for this for DIY use 😀 I'm extremely interested in building a 2 channel DAC using this chip.
This is exactly what I want to do, but I need to be able to purchase some samples. Still no answer to my sample question...
I would very much appreciate being able to buy a few samples.
Thanks!
Russ
Hi Russ,
I have contacted marketing to find out the process, I will put the into on this thread ASAP.
dusfor99 said:Hi Russ,
Thank you. I am clearing out some time to start the layout.
Cheers!
Russ
Cheers!
Russ
Hi Russ. I am working on a schematic for a layout also. I have been 'experimenting' with the demo board.
How are your skills at the PIC micros? This part will need a I2C controller on board. I am thinking a PIC16F677 at minimum, maybe a PIC16F882 if I want it to do some other processes.
Found this:
http://www.cmoset.com/uploads/4.2.pdf
It looks like Dustin has been giving some seminars !
dusfor99 said:
I fail to see what Treatment of anti-depression drug-induced sexual dysfunction with apomorphine has to do with this discussion.
Kuroguy,
Ya, I was also wondering why it shows up if I do a search for my name a tthe US patent office. There is an invertor with the first name Dustin, and antoher inventer with the last name Forman. ohwell, what can you do?
Dustin
Dustin
Of course if I was you I'd be telling everyone that it comes up when you do a patent search for your name. That's the kind of information that makes a great topic of conversation at social events.
DPLL register
Hi Dustin,
If you have some time, could you please expand on the implications of changing the DPLL register. I noticed that your default in the data sheet is different from the default in the Sabre8 GUI.
Thanks!
Hi Dustin,
Thanks!
Modded the demo board
I modified up the demo board a little bit.
http://home.columbus.rr.com/rossl/images/mod/sabre_demo_xfmr_out_1.jpg
At the bottom, an 110 ohm AES/EBU cable brings in SPDIF to a PCB on the far right. That PCB features a Wolfson WM8804.
The Wolfson receives the SPDIF and decodes it to I2S. It also features jitter reduction, so I am using the lowest PLL bandwidth register setting in the ESS Sabre 8.
Other PCBs to the left of the Wolfson board are a low jitter clock and a low noise AVCC regulator.
I removed the 40MHz crystal osc section from the demo board.
You may also notice that all seven op amps have been removed. Yes, the first three pages in the schematic are gone.
The analog output now consists of a few resistors, some mica caps, and two Jensen 4:1 transformers. The transformers are expensive, but I had two in my parts box that have been sitting here unused for a couple years.
JT-10KB-DPC price is US$71 each.
http://www.jensen-transformers.com/datashts/10kbdpc.pdf
When I read the Sabre8 whitepaper, I realized the Jensen 4:1 transformer would be a good match for the Sabre8 as long as the load is 10K or greater. The transformer lowers the output voltage, presents a lower impedance to the load, and a high impedance to the Sabre8.
There may be some better transformers for the job, but I don't have any of them right now.
The general strategy for the transformer coupled output started from this document.
http://www.jensen-transformers.com/as/as093.pdf
That picture was yesterday.
This is what it looks like now. 😀
http://home.columbus.rr.com/rossl/images/mod/sabre_demo_DAC1.jpg
The little rack box I bought had a eight watt power supply. I dont need +/- 12 volts any more so it only uses a 5 volt supply. Without the op-amps, this is probably using only a watt.
http://home.columbus.rr.com/rossl/images/mod/sabre_demo_DAC2.jpg
http://home.columbus.rr.com/rossl/images/mod/sabre_demo_DAC3.jpg
OK, so the back of it is ugly. 😱
It has the transformer isolated outputs on the left,
RCA digital in in the center. USB and TOSLINK middle right.
I didn't put in a switch, so if I want to switch use either the coax or TOSLINK I have to rewire it to the one I want.
I bought the rack mount chassis on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190195409458
I don't know what this thing did in it's former life, but now it's a high end DAC that sounds really good.
Dougie085 said:So how would you feed this DAC a DSD signal? Is it even possible in a DIY sense?
I don't know the answer to that question. I am listening to a SACD right now though. See the thread where I mod the Oppo 981.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=95972
The MediaTek MT1389 controller chip converts DSD to 24/88.2 PCM. It sounds great. However, you need to mod the player to get the 24 bit/ 88.2KHz out of the box.
- Digital Line Level
- ESS Sabre Reference DAC (8-channel)
