if you are
talking about the ESP P3A
well yes .... if you are looking for a simple to make, very effective, with unbeatable sonics. very good drive, extremelly music and sweet amplifier....this is what are you going to get ....
also very cheap to make most of things said in ESP pages are very correct and if you can follow procedure you will be amazed of the results ...
i recomend that you get pcb from ESP unless you have the guts to make your own ( sziklai pcb can be very tricky and some small details may alter the perfomance)
Ulternative will be to make a DX amplifier (presented in the forum with extensive threads and loads of support )
The DX amplifier is more than correct .... simple ...very acurate ...detailed rich sound both in low and high ends ....meanwhile midle is transparent with alot of headroom and sound stage ....
now ...this is a question of taste
DX is very acurate ...too square i'd say or even too perfect ....P3A is more free more ready to escape you may choose either .....
it all ends up to what you want
You may also consider the original Symasym for this power range, by MikeB
http://www.lf-pro.net/mbittner/Sym5_Webpage/symasym5_3.html
I have built 2 of these and they are nice
in which thread can i find DX Amp?
Are you BLIND?
Are you BLIND?
That was my first reaction too
But he had already found the nest...
He is on forum long enoughcommon guys ... be nice to people ...this guy is not an everyday forum user .... so he doesnt know that Dx thread has been so rich and arround for so long ....
regards sakis
diyAudio - Search Results
CRT made the most beautifull Dx boards i have ever watched
It is my prefered one...i love blue and the way he did the board.
Thank you Sakis.... the telephone call from Greece was very pleasant...nice voice you have.... the transistors you gonna sent will be tested as drivers and VAS and i will let you know...if the advantage was clear while compared to BD139/140, then they will be the standard for Dx amplifiers.
I will recall the Dx amplifier thread..will use CRT picture to post something there to have the thread in evidence...interesting that i turn invisible.
ahahahahahah!... so fat the way i am..... and invisible!
regards,
Carlos
regards,
Carlos
- ESP 60 watts
