Hi, I am newbie in tubes and I need some help from you guys.
I use a schema from J. Broskie, but when I am doing a frequency response, I can see some problems. Since it is without feedback, I took the curve directly from the output, but I do not like the phase shift. Is this okay? Or should this be compensate to have phase margin at least 60 degrees?
Thanks for help.
Schematic:
Frequency response:
Original schematic:
The Tube CAD Journal, Electrostatic Headphones
Thanks for help.
Schematic:
Frequency response:
Original schematic:
Phase shift automatically comes with the amplitude response variation.
Since you have no overall feedback, the concept of phase margin is not relevant.
what if I add negative feedback?
Looks like -90 phase at unity gain, so it should be ok with nfb.
