With the help of countless individuals from this forum, peticularly Sheldon Stokes and Russ Knotts, I stand within stikining distance of a beutiful pair of ESL hybrids. Of course I am an idiot, and am having a problem and so I look to the collective wisdom of this forum to point out my peticular lack of intellegence on this occasion.
A few basics:
ESL panels using ESL info xchange stepups
50:1 transformers
Crossed at 225 Hz
Crossed to the Peerless CSX 8 inchers (beautiful sound by the way in sealed setup)
All powered by a Hafler 500, 225 watts to each chanel, and more body than I have ever owned in an amp.
The problem:
The "balance" between the sound output of the woofers and the panels seem to be off. The moronic termonology "the panels seem quieter than the bass", or maybe "the bass from the woofers is overpowering the panels".
Alone of course, the panels sound beautiful, save the fact there is no bass.
Now I noticed the following: the "off" impedance of the woffers and panels is 6 and 8 respectivly. So is more power being given to the woofers due to this difference in resistance, and if so can i just add a 2 ohm in seris??
Also, if raise the step up voltage another notch, will this help at all?
Thank you for the help again.
Brian
A few basics:
50:1 transformers
Crossed at 225 Hz
The problem:
Brian
I am not sure what exactly is your situation but the only good solution is a separate amp for the panels. Raising the step-up (and polarising) voltage will certainly help but be careful as this will very likely induce sparking
I agree with analog- biamping is the best approach for hybrids. And you may want to closely examine the eq you're using for the ESL panel (you ARE using eq, aren't you?); textbook approaches do not always give the right results in the real world. Measuring the panel output may give you some surprises.
ESL details
Hi Brian,
How big is your ESL panel. What is the size and is it made up of small panels. Did you use 12 micron Mylar ?
I would like to have some details as I have been planning on building one myself. I have everything except the stators. Details of your ESl would come in very handy. Can you put up a picture?
Thanks.
Ashok.
Hi Brian,
Thanks.
Ashok.
