ESL 57: painting front grill: easy ?
I have a pair of ESL with black front grille. But I have seen also bronze colour front grille. You can use black automotive spray, but best to take it to a car spray paint centre and have it painted black.
The internal dust covers had some grey paint on it. I have replaced the dust covers and I can live without the paint.
Well, the guys at a good car spray centre (not the backyard one) are skilled enough to find/mix the matching colour, if you show them the original...
Problem is, if you try to do it yourself, the paint might block the grille gaps.
This is indeed a good solution.
I have my own (serious) equipment for car painting. The paint itself should be
quite dilluted to avoid what you mention.
But I need a reference for the colour.
Does someone have a reference for the bronze colour ?
The RAL number (or any international colour standard) would be great.
For example, copper brown could be close to original "bronze" colour: RAL 8004.
www.RALcolor.com | RAL Color Chart
Hard to see it on a computer screen though.
Fabien, it isn't paint on the ESL-57 grilles. They are anodised aluminium. If you do a search for anodising companies you will find many commercial operations who can do a range of colours. They won't be able to match an old speaker, you'd have to have both grilles done at the same time, but you could have black or purple or whatever....
I wouldn't recommend painting them because of the risk of clogging the grille.
Robert
