I'm interested, too. I have also one question; is there a preferred input tension for this ADC?( I'm building a phono and I don't know if 1v output is good or not; my idea is phono - ADC- DSP crossover - 4 dac - 4 amplifiers )
many thanks in advance
I think this ADC chip can do the RIAA for you, so you may not need the phono.
It can do RIAA filtering but as it is shipped, only at 48Khz. To make the RIAA work at other sample rates I will need to add custom biquad filters.
It may be better to apply such a filter later in the chain in any case.
I will give more details on this as I can.
Working on it now, My guess is it will take my a few weeks - then I will send off for prototypes.
They actually changed the part since last I worked on this board, so I have bit of work to do. 🙂 I have the new datasheet - so I am excited to get back on it.
Hi Russ ... well, I could almost sense excitement through your last post 🙂
In the meantime a question has popped up and so, just to be sure: Are you making a solution that will (also) allow for 384 kHz/24 bit recording to a PC via USB - or are your design goals something different?
Best regards,
Jesper
Best regards,
Jesper
I am indeed excited about it, as I plan to use it to create some high quality rips of my own vinyl. 🙂
This module will not handle the USB side of things. 🙂
There is another one for that.
Aha - so now I'm (also) curious ... Which one would that be? When checking your website I don't see such a module ... Or am I missing something?
Greetings,
Jesper
It is the USB module which is also currently under development.
It have been updated since my last prototype work since XMOS has come out with a new device.
... just to make sure ... will the USB + ES9102 module also handle 384 kHz/24 bits? Any links to the USB module here on diyaudio?
🙂 Jesper
🙂 Jesper
Head amp
Same here 🙂 Using some an excellent turntable platform with good tonearm and cartridge with good wires.
What is needed in addition to your ADC, is a super low noise moving coil head amp with nominal 64 dB gain flat from say 10Hz to 100kHz, and changable gain setting from 40-70 dB for MM cartridges and low output low-output-MC cartridges a la Ortofon. DC coupled and no bias current going through the cartridge.
Tricky stuff!
Cartridge loading must be changeable, too. Both MC load and MM load. Easy stuff 😀
Input protection for your module will be needed but of a type that has minimal affect on sonics. Preferrable DC coupled.
Tricky stuff!
QUOTE]
Tricky stuff!
QUOTE]
You might be interested in the Retro - especially the LOW-Z version for MC. It is not well suit to MM though.
Currently I use tape out of my pre connected to a laptop via an RCA to mini phone plug to do hi-res vinyl rips. They sound real good! Looking forward to seeing the ADC module and new USB module.
Well Rus this really put a smile on my face - I have been looking for a topnotch ADC for some time as I have decided to put my vinyl collection onto hard disc, before decrepitude finally overcomes me.
Perhaps building in a full blown phono stage may create analogue/digital problems? re. the spec. that staccatiss has outlined. I have such a phono stage - Talk Audio's MC3 and I can say that it is a joy to use - no noise and totally versatile for loading and gain and very sensibly the PSU is a seperate item with high quality umbilical connection.
I think that if Rus does build in such a phono stage it would considerably raise the unit price?
There is no way that I would use a PC/laptop connected to the net as I would go mental if I my 1000 + LPs were lost or corrupted. With the help of my Dutch mate who is an IT man I intend to build, probably using an A/V chassis, a dedicated music storage package and backed up with at least two copies.
Not sure it is low noise enough. We need something really low noise and that means using discrete devices.
I tried to buy the Retro but got an error on the web page.
I thought that Russ´ADC would internally take care of the RIAA correction, so only a flat gain head amp is needed. No RIAA correction needed which is a big relief! The ADC can handle the RIAA decoding AFAIK 🙂
One could also use a transformer instead of a head amp to get at least 20 dB gain and then use a more simple OPamp based flat gain amp. Might have some advantages to use transformers here to separate grounds, and get balanced signals 🙂 with which the ADC will perform better.
Music file backup is mandatory. Best is to have one backup in a bank deposit where it is fire proof.
Sure I can give you an update.
I have the design about 80% complete.
I have prioritized the USB module above this module partly becuase this module will very likely be used with the USB module quite a lot.
So I am designing the USB module so that it can connect to a DAC/ADC as a master.
The ADC module will be able to act as an asynchronous mode slave. Which the ESS ADC chip does very well (I have an eval board").
So I figure I really need the USB module to effectively test if the new ADC is working well.
Keep an eye on the USB thread I am going to be posting some news there soon.
Cheers!
Russ
Cheers!
Russ
Excellent news!
If you need an extra pair of eyes checking the design (analog+PS section), email me.
Cheers!
Russ
- More Vendors...
- Twisted Pear
- ES9102 ADC Module
