ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
And what number is our target ?
No real target but a required minimum number. That does not take away that 500 would be nice 😉
The design is not 100 % determined as we are playing with some ideas we got from participants in the GB. Despite earlier comment it could very well be that the board will be slightly larger.
Looking at the supply PCB, I don't know if it is too late to add option to use discrete diode rectifier bridge. Should be easy to put on the board. Thanks.
Hi Algar_emi
Looks like Jean-Paul has missed your point, very busy at this time.
From what I know, the actual PSU V5 remains the same.
Consider it as a very good Pre-regulator, feeding 4 LDO on DAC board.
"Moderator Emeritus" position is requested here for further comments :worship:
MisterRogers, 6speed, rellum and zibra, welcome to the party 😉
I'll Post this week the GB closing date, don't know 8th or 12th of October.
I've to evaluate the final costs of parts Kits, according to V3 release.
It seems that PSU will remain the same.
Please check your inputs 🙂
Hi all, I can't believe my eyes when I see the number of the PCB's wanted by you all. This for a yet non-existing PCB (there are several versions but none of them has been chosen as final version), that must be an indication that the 2.6 is really liked ! It is not vaporware, there will be a PCB as we promised it.
I hope you all won't be disappointed by the V3. Originally it was called rev. 3.X but Korben calls it V3 and I will adapt as it sounds like a kind of secret weapon to me 🙂 I did some changes and I am still thinking of further improvements but it is quite hard as 2.6 was already a fine PCB. In fact it would be the most easy solution to have the 2.6 produced with gold plating but you know we usually choose the way of most resistance. Changes will be subtle. No USB, please stop asking. There are several USB solutions out there. The Subbu DAC is SPDIF/I2S. A possible USB version is maybe something for the near future but it will be a different product with a different name.
We found a possible BG replacement but they are also partly out of production and partly hard to find. That gives hope 😉
Truepaul, Koeniwo, jacobthellamer & DRZ1 : welcome to the party :wave:
Thank you to others who have signed up within the Spreadsheet.
Many thanks to Jean Paul & Subbu hard work :worship:
As unexpected, Subbu's DAC V3 GB will be closed the 18th of October.
Signed myself into the Spreadsheet and added 10 ES9023.
Hey guys, If at all possible could we get some other chips from ESSTech when we are ordering?
I would also like to have the following chips added:
2x ES9112 Sabre32 Ultra 32-bit ADC listed at €15.83 at Ismosys
2x ES9016 Sabre32 Ultra 32-bit 8 channel DAC listed at €25.92 at Ismosys
It would be so cool to play with ADC and 8ch out !
More channels to the people !
