Thinking its best to wait for the test results for v3 before building V2,6..😕
Edit:"WM8804 is viewed as "easy to get" and would be included in Parts GB."
Isnt the WM8804 inkluded?
Hi Ryssen
You can build your V2.6 without waiting for V3 to be available.
WM8804 will be provided and included in SE Parts Kit.
Phil
PS : Hope you'll be delivered soon.
hi, just fill in sheet
if i want a BAL full kit without PSU, should i input DAC x , ES9023 x2, Bal x1, am i right?
Hi totohung
BAL full kit without PSU is : 2*DAC V3 PCB + 2*ES9023 + 1*SE Kit + 1*BAL Kit
You're welcome
Phil
Thanks for all the effort korben! Looks like we have crossed the magic number..as was to be expected!!
Hi gopib
Yes Magic Number is crossed, many thanks for your interrest !!!
So, now questions is : "What will happen now ?"
Then we have to invocate "Moderator Emeritus" for further explanations
PS : Magic Spreadsheet is still alive 😀
Hi tubo
Please add your wishes in the "Magic Spreadsheet", link is shown in Page 1
You mean 1 SE DAC + 1 PSU or Parts Only ?
If you want a working SE DAC V3 then you need :
1*DAC V3 PCB + 1*ES9023 DAC Chip + 1*PSU PCB + 1*SE Parts Kit + 1*PSU Parts Kit
Phil
Phil
#76 Updated.
I am very new to DIY. However I dont want to miss the opportunity.
I have updated the sheet. I will be making two DAC's. Can someone please check the sheet and confirm I have put the correct numbers. Thanks in advance.
DJ
#76 Updated.
DJ
#76 Updated.
DJ
Hi DJ
If your goal is to build 2 DAC's your input is correct.
1 SE DAC = 1*DAC V3 PCB + 1*ES9023 + 1*PSU PCB + 1*SE Kit + 1*PSU Kit
Hope you'll enjoy building this great DAC 🙂
Phil
Hi all, I made several new versions but we feel the 2.6 was already very good and surpassing it by a new design is not the road to follow. Original thought was to make one large PCB with both DAC and power supply on one board but we decided that is not optimal. Normally I am not too shy for changes but we both really think the board should only be slightly changed. So I polished the 2.6 to a 3.0 and did some subtle improvements. Large changes of an already proven design really is playing with fire 😉 Positive effect is that it will have the same dimensions as the old one so retrofitting will be possible.
One of the subtle improvements is that the new 3.0 board will be gold plated. Result of this is that the board will be higher priced. More details will follow as we try to find a replacement for the BG caps. We already did but no details for now.
Hi DJ
Phil
Yes I intend to build 2 DAC's, Thanks for the confirmation.
Is there any provision for USB input which can be added later?OR any USB adapter slot on PCB?S/pdif or I2S. If you want optical, you can use an external toslink to S/pdif converter.
You must provide your own usb->i2s interface.
Thanks,
I just read about some comparison between Sabree DACs-
http://www.diyaudio.com/forums/digi...23-sabre-premier-dac-integrated-op-amp-2.html
A review of ESS's DAC lineup is interesting (numbers are for 8 channel mode on the 8 channel parts):
start with an unbuffered voltage output and shared supplies
9023 - -94dB THD, 112dB DNR
buffer the voltage output, separate analog and digital supplies
9006 - -102dB THD, 120dB DNR
switch to 64 pin package and add more supply pins
9008/9012/9018 - -108dB THD, 120dB DNR
go back to 48 pin package but change to current mode out
9016 - -110dB THD, 124dB DNR
keep current mode out and switch to 64 pin package again
9008 - -118dB THD, 128dB DNR
do some die layout improvements over the 9008?
9012/9018 - -120dB THD, 129dB DNR
So is that ES9023 has more distortion level than older chips on paper? with only 94bd THD compared to other chips?How can be a true performance in real world?
One question-
Is ES9023 better than other Sabre chips?The sound quality comparison?
THD is 94db compared to rest(around 102-110db).
If these are your questions you likely have some reading to do before deciding which DAC to build to meet your objectives.
ES9023 is 1/20th the price of the ES9012 for single chip.
I already registered for a kit but never experienced an ESS dac, only BB and TDA dacs. IS something special with this ESS dacs even we will have the basic one from them ?
BB sometimes are laid back,ES are perhaps better performer.
Hi some people even think ES9023 sounds better than some ES9018 implementations. I don't know about that, I can only tell it sounds way better than it should. For instance AKM chips are no comparison.
The same technology that is used in more expensive ESS chips is used in ES9023.
- Group Buys
- ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
