Guys, check this out
SABRE ES9023 DAC PCB+ES9023 DAC CHIP MOUNTED+FREE HCMOS CRYSTAL | eBay
It has WM8805 and pcm2707 receivers and it can also have I2S input from external sources like TE2022 USB module. The crystal can also be changed. Looks very tempting to build one.
A prompt reply from the seller
"You will be given ESS9023 dac chip + one HCMOS crystal along with the board. Other components you can get it from digikey, element14, ebay, headfishop, etc"
So it's up to you to chase all other components, presumably you'll get a BOM and/or schematic after purchase.....!!!!!!
Personally I don't think it's worth the money.
