I have bought quite a few pcbs mostly from China and had very few problems.
One problem was resistive tracks on a mixer causing hum. I had to add wires to short out the resistive tracks.
The only actual pcb track fault was a broken track on an amplifier pcb.
I tend to buy in batches of 10 to 25 so I suspect not much testing other than a brief look over is done.
Clearly I need to specify copper ounces to help with the resistive problem and also include a ground plane.
I just wondered if any one else had had any similar problems ?
Oh, yeah, i had such pleasant experiences several times already. and the nasty part is that some pcb's look perfect and if you measure them, there are no shorts or interruptions. but after they are assembled the board fails to work. this is mostly due to interrupted vias, or microscopic shorts which are not detected in the testing phase.
when i order a batch of pcb's i require 100% electrical test, not just visual inspection like many pcb companies consider QC. there are few ways to test a pcb. leaving apart the traditional method, where a myopic lady stair over a pcb without founding an interruption even if the board is broken in two
and of course, the final test, after the board is fully assembled, for medium-large quantities the bed of nails is used, again...
for digital circuits which contains one or more CPU's or PLD's, the JTAG boundary scan test is the preferred method. this allows several devices to be cascaded and tested. also, JTAG interface which became a standard, is used for programming and firmware update in the past decade, without the need to remove the device from the board or even to open the box.
It is tempting to buy cheap but a fully stuffed board that needs to be thrown out is useless and expensive. The possible permutations of pcb errors is huge.
The first electronics company I worked for bought in cheap pcbs and the etching was poor with loads of shorts. Of course the shorts had to be under an IC which needed desoldering to cut the short. Sometimes desoldering the IC wrecked the pcb anyway.
Hi nigelwright7557
I have good experience with Olimex. I only buy a few PCBs at a time, and really like the option ot get different pcb made on the same panelized board as long as it fits dimentions.
I have experienced not faults on their behalf yet.
What companies in China have you used and have good experience with? Like to broaden my look![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Happy new year Baldin![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Chinese supplier pcbcart.com
I buy small pcb's by the 100's from pcbcart.com and have yet to see a fault. The only difficulty I've had is understanding exactly what they are asking me - when I've made a mistake or i've asked for something out of the ordinary. I continue to use them and would recommend them.
A number of years ago I used to use a small local (UK) company for big PCB's - 30cm+ and had repeated problems, usually intermittent conductivity of via's or of plate-through pads, occasionally over-etched (thin) tracks. That company went out of business.
In my experience..
(1) The general attitude of a PCB place seems to matter more than anything. Some places are really professional and try their best to put out a good product, and others say "hmm, that's strange, we'll look into that" when they ship you a bunch of defective boards. If a PCB house pisses you off, go elsewhere.
(2) Don't push the process. If a PCB house advertizes 8/8 or 4/4 mil trace/space, don't send them a board with a big parallel bus laid out as 8/8 or 4/4 respectively - you can pretty much guarantee that you'll receive a board with those bus lines open or shorted together. Likewise, don't use the board house's minimal drill size, or you'll find yourself with high resistance or open vias.
If you don't have a choice (eg, putting a 0.5mm SMT device on an 8/8 process board) talk to the board house before you place the order. They may suggest changes to your device footprint that may eliminate any potential problems, and if they're a good shop, they'll inspect the first few boards they build and fine tune their process to make sure your board gets made right.
(3) Don't underestimate the cost of testing/reworking/throwing out assembled boards.
If you're building a cheap PCB which is cheap to test, and you don't mind ordering extras and throwing out the odd board, by all means use the cheapest PCB house out there.
And if your board has to be reliable in the field, eg. if it's going in an automotive, broadcast or industrial application, under no circumstances should you ever cheap out on the PCB. Don't push the process, use a better process than you need, and if your components are expensive then get a full electrical test done on the PCBs before assembly.
I literally fought with my last employer about this - they went from a $50/piece to a $30/piece PCB vendor for a multilayer PCB with about $500 of parts on it. Yield dropped substantially, and we found ourselves short on boards and wasting money by discarding boards. I spent late hours fixing boards to meet shipments, we had a couple boards fail in the field which pissed off customers, and as the board designer/"owner" I ended up getting blamed for the whole mess. Thankfully they saw the light and changed back to the original vendor.
I literally fought with my last employer about this - they went from a $50/piece to a $30/piece PCB vendor for a multilayer PCB with about $500 of parts on it. Yield dropped substantially, and we found ourselves short on boards and wasting money by discarding boards. I spent late hours fixing boards to meet shipments, we had a couple boards fail in the field which pissed off customers, and as the board designer/"owner" I ended up getting blamed for the whole mess. Thankfully they saw the light and changed back to the original .vendor.
But for sure this low cost vendor looked great on the slides, which were presented to your management and somebody got a good bonus for that great cost cut.
...so far I only ordered once from a Chinese vendor, basically the board showed good quality.
Good quality, but wrong copper thickness, I had ordered a 70µm base material thickness, but they made in 35µm. And the best was that their reaction when I complained:
Choco: 'My measurements show approx 50µm copper, means 35µm base material +15µm galvanic. I ordered, 70µm base material....'
PCB-Company: ' Trust us. You cannot measure the copper thickness without special optical equipment.'
I did not answer and did not explain 4-wire-measurement...
Another time I ordered from Würth:
WEdirekt ? der Online-Shop von Würth Elektronik | Leiterplatten und Stencils ab 1 Stück | Platine, Leiterplatten, Prototypen, PCB, SMD-Schalter, Stencil, Lötpastenschablone
Perfect, but not cheap.
Wasn't any of that. The purchasing department found a new vendor which quoted lower prices with the same specifications as the old vendor's process. They felt that they were doing the right thing, and changed vendors without asking engineering.But for sure this low cost vendor looked great on the slides, which were presented to your management and somebody got a good bonus for that great cost cut.
There wasn't an official "ask engineering first" policy in place at the time, so nobody was ever really was at fault. Didn't take long after the PCB snafu before an approved vendors list system went in.
Handling vendors and knowing when to recheck with engineering, that's in fact more difficult than it looks like!
I am aware of that, but just could not resist to put that sarcastic comment above.
![shhh :shhh: :shhh:](https://files.diyaudio.com/forums/images/smilies/shhh.gif)
I was a little naive with pcb quotes to start with, I just asked for the cheapest option.
I got very thin copper on the tracks and the copper with resist scratched off looked a bit black so was probably very cheap copper.
I also should have asked for a ground plane.
Well we live and learn.
What was really odd was while the pcb track had a crack in it the whole pcb looked well etched with no shorts or over etched areas.
Perhaps a hair had got on the photomask and caused the track break.
I get all my pcb's from Eurocircuits. Not cheap but very high quality, according to them they can even do 50 layer boards for aviation etc.. imagine the process and quality control required to do that!
These are nice video's of the production process on their website: Eurocircuits | Making a PCB - PCB Manufacture step by step
They don't seem to be THAT expensive, once you go over few numbers of boards, they become pretty good pricedI get all my pcb's from Eurocircuits. Not cheap but very high quality, according to them they can even do 50 layer boards for aviation etc.. imagine the process and quality control required to do that!
Highly recommended. I've gone to them multiple times for various projects, both personal and professional, and they've never let me down.I still use Alberta for small quantities. They aren't as cheap as others, but I've never had a quality problem. If you download and follow their guidelines you'll get the lowest cost and highest quality.
One thing I will say though - if you're doing anything smaller than a SOIC in your design, spend the extra money and get solder mask done. Likewise if you're doing a prototype board that's going to get parts changed - the solder mask will keep you from peeling traces.
- Class D
- Error rates on pcbs.
