I am using Erno's 320 jfet phono with his 255 super shunt regulator for a while and it is super beautiful until one day........ I discovered that one channel's voltage drifts up and down. Since the 255 regulator is a CCS, I think the 320 is drawing too much current therefore I made some fine tune on the 320 and then problems - I measured one channel with 1mV DC offset while the other is drifting between +0.2V and -0.18V even with the DC servo IC plugged in. I did nothing to the 320 except I took this out from the chassis and fine tune it. I believe such a high DC offset is a concern. Am I right?
320 uses 4 pairs of N P input jfets with cascodes. I measured the junction between the four 2SJ74 input jfets and cascodes, they are 2.023V, 2.257V, 1.744V and 2.015V on the problem channel while the normal channel is having readings close to 2V on all of them. Could such a variation cause the DC offset to such a high degree?
Erno is too busy for his last batch of orders and is not able to help. Can anyone give me some clues?
RIAA Phono amplifiers have very high gain.
So even a small dc-offset somewhere can be amplified
and reach several Volts at output.
But in your case I think there is an issue.
If one channel is very good, shows 1 mV,
the other should not show +200 to -180 mV variations.
This is not what you want.
But I do not think it is harmful to anything. You do not have to be afraid, as long it is below 0.2V.
Hope someone can figure this out.
If not, you have to wait until Borbely can help you.
