hi,
had a hard time looking for the above mentioned chip locally.
i had spend the whole of sat asking ard but in vain.
so am here asking for the equivalent replacement chip for IXCP10M45S.
reason for asking cos' if i were to order from the states, the cost of shipping is more than 10 times the chip itself and thus certainly is not the way for me to spend my hard earn $ like that. 🙂
thanks
thanks
You could order them from diyhifisupply in Hong Kong. I'm sure possible replacements will be just as hard to find. Such as DN2540 (Need to cascade them because performance of one is not as good as one 10M45S.) Or the IXUS 01N100D which has been reported as being better than the DN2540 soundwize)
What would be the best however in your situation would to build something like the C4S which uses common transistors but is known to perform and sound well.
You can use either cascaded or single. But I saw measurements by Gary Pimm:
CCS performance measurments
That show the performance of one DN2450 comparing not so favourably with a 10m45 if both are used single. The cascoded DN2540 has excellent performance.
at what sort of voltage was the test at................i was thinking for anode resistor replacement (150v +)
Dunno. But from the duties Gary used them for. I'm guessing he also measured them in exactly the situations you'll be using them.at what sort of voltage was the test at................i was thinking for anode resistor replacement (150v +)
i have got a k+k cascode kit.......someday i will give it a try as a cascode and then single.
the only thing with that is in the cascode kit the lower mosfet is a IXTP01N100D.
so if you want 2x DN2540 you have to get 2 single kits.
Sure it is not the top position? This guy also from the Uk shows it on top...and I think he uses the K&K ones as well. http://www.triodeguy.com/Triodeguy PDF files/Triodeguy Constant Current 50_300B SE Circuit.pdfthe only thing with that is in the cascode kit the lower mosfet is a IXTP01N100D.
any way the best in all cases is meant to be the IXCP10M45S cascode.
but you just can't get them in the UK. something to do with the supply contract.
Hallo Bas,
Je kan hier eens proberen.
IXCP10M45S Ixys Current & Power Monitors & Regulators
Laatst ook wat besteld, ze zijn snel en zeker niet duur.
Groet John
Groet John
Hallo John,
Ik bestel ook vaak bij mouser. Gebruik momenteel DN2540. Maar wil overstappen op 01N100D deze schijnen nog beter te zijn.
I often order from mouser as well. I use DN2540. But want to use the 01N100D in the future since these are reported to sound even better.
Groeten Bas
Bas
Groeten Bas
Bas
01N100D - info not on the datasheet
These are promising parts with nice low capacitance, great working voltage, etc. and also have the benefit of relatively large Vgs at tube amp currents - this makes it nice for the top device in a cascode because it gives the bottom device some Vds to work with.
I purchased a tube of them to try out. Here are some curves I traced out, which are not published on the datasheet.
Michael
Hallo John,
Groeten Bas
Bas
Michael
The OP (original poster) wanted replacement.I thought you wanted replacement because you could not find them anymore
yes, i am looking for a replacement part that is equal to ixcp 10m45s as i do not seem to be able to locate it locally.
There is no exact equal to the 10M45. As stated by others the DN2540N5 can be used in some circuits. The DN2540N5 will work in the Simple SE, but the 330 ohm resistor value might need to be changed. I have tried the DN2540N5 and it worked OK, but I am at work and my notes are at home.
hey-Hey!!!,
The IXYS chips deliver current at lower( more negative )gate-source voltages. Putting one of these over a Supertex MOSFET looks like a very good idea as the lower device will have more voltage across it( reducing g-d capacitance ). For the points I looked at it was OTO 1.7V for the DN3545N3 and 3.5V for the 10M45. Our CCS boards use the TO92 on the bottom and TO220 on top so the experiment is easy...🙂
Probably have to re-evaluate the lower MOSFET's gate stopper value to insure it isn't singing in the RF due to lower effective gate-drain capacitance.
cheers,
Douglas
cheers,
Douglas
hi george,
great that DN2540N5 will work for Simple SE. pls let me know that value to change to for the 330ohm resistor (R13 & R23).
i do have another question. can i use FRED diode DSEI12-12A on Simple SE (D1 & D2) as it was used in Tubelab SE (D2 & D3)? forgive me for the silly question as i just wish to make sure 🙂 initially planned to use ISL9R8120P2 for D1 & D2 in Simple SE.
DSEI12-12A rated @1200V 11A
ISL9R8120P2 rated @1200V 8A
guess the answer is obviously a yes 🙂 just want confirmation from the seniors.
- Tubes / Valves
- Equivalent to IXCP10M45S?
