I finally installed a sub sony with a amp sony aswell.
Since I bought the amp, I knew that it was a little bit small for the sub (250W). But since I don`t have a huge sound system, I said: No problem!
Now, when I play my system, in some songs the sub doesn´t sound the same way, because of the song´s bass level.
My question is:
DO YOU RECOMMEND ME TO USE A MUTE EQUALIZER IN ORDER TO CONTROL THE SUB?
Like the baby Kenwood, that has it.
My question is:
1. what do you mean by 'mute equaliser.
2. Sony is bottom of the line sub/amp equipment
3. If your referring to an equaliser, this could fix the frequency response.but most likely the bad sound is due a bad subwoofer alignment or an uncontrolled woofer.
http://www.diysubwoofers.org/
