Hello all,
I´m working in a EPSON S10+ projector to bypass the Lamp Check process. Verifying the ballast, that uses 5 pins and UART protocol.
In OSRAM site, I´ve found a document with the USART commands to communicate between projector and ballast.
I´m starting to work to create a "emulator" using PIC microcontroller, but first i´m start to capture the data.
If anyone trying to do this too, please welcome 😀
There is the document:
http://www.osram.com/media/resource/HIRES/333550/osram-uart-protocol,-version-1.3,-22.03.2007.pdf
UNISHAPE | Tools | OSRAM
Unishart is the Application to configure the lamp (ballast).
Comdek
Comdek
Solved the problem.
I´ve just removed the old bulb from reflector and installed a HCI-T 150W bulb.
Model:
Osram powerball hci-t 150w
Just crack the outside glass using a ahesive tape and a hammer and get the bulb.
Model:
