Why?
I've winded a transformer different times and never get more that 2-3A. It were a PC Power Supply of 350W. It's a classic transformer not a Torroidal...
I reach +/-35V but the A is too low for my amplifier..
What's maybe the reasons?
I'we winded by this way.. ====== Is isolation
Secondary 2
Primary 2
Secondary 1
Primary 1
CORE
Is it winded in the wrong way? How should it winded? Or do u think that i should consider to pick another transformer???
Secondary 2
Primary 2
Secondary 1
Primary 1
CORE
If you're trying to rewind a ferrite core transformer from a switched PSU to function as a regular 50Hz mains transformer, my advice is definitely to stop. It's not supposed to work at that frequency, and you're dealing with deadly voltages here!
Rune
Rune
He is trying to use it as a SMPSU...but I think his input current is definetly not enough...from the previous posts that he had...
What are the dimensions of the core (cross-section area of the middle), what is the secondary wire diameter, do you use EI transformer with or without air gap?
He does have some previous posts on his SMPSU right here...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=19107&perpage=15&pagenumber=8
There's a picture of it there...shows a PC EI core got scrapped for his trafo...
Now i use a car battery with 20A!but I think his input current is definetly not enough
Now with a chargedcar battery (i don't know ho many current produced but a lot i think! 🙂) i've +/-36V@7.5A!!
Enough no??? 🙂
thanx to all the ppl that gave an help to me!
Enough no??? 🙂
- Enough Voltage but not Ampère...
