Endevco Signal Conditioner 133 frequency response
It seems, that I'm having an issue with my Endevco 133.
If I measure the frequency response w/o any sensor attached, it has a big bump between 40Hz and 60Hz. Other than that it seems to work OK.
As I bought it used from eBay some time ago, I can't say anything about the conditions it has been used in or about it's age.
Ideas/ advice would be appreciated.
Best
Stephan
I'm using an Endevco Model 22 Accelerometer and the manual you found to set the parameters. Seems to work fine!
As the bump is around 50Hz, my assumption/ fear is that the 133 might have an issue with it's internal power supply.
That 1nF cap - where exactly should that be put? In series with the accelerometer?
