encoder wanted
I'm kind of new to this, so I'm not sure exactly what you're looking for.
What is a "classic quadrature incremental, 50 ppr, volume control encoder"? Is this a "rotary encoder" type of switch as can be found at www.Digikey.com ? Does it have pulsed, Gray or BCD coded output?
It might help you to find what you're looking for if people understand what exactly it is. ( Or I might be the only one that doesn't understand. But I would still like to learn what it is. )
Regards,
Tom
yes, rotary, with pulse output, 3 wire plus 2 for supply, 50cpr means 50 pulses per revolution(at least), something like this...
yes, the cheapest are 6$...but if you want something that will give you a good smooth sensation when you turn it, you need something more solid, metal casing first...in my head there's something used in cnc industrial machines, heavy and...expensive!!:bawling:
