Hi guys,
I’m very new to speaker building (I do have woodworking skills though) and need some advice building a pair of two way speakers for the purpose of watching movies on my big screen. I’m not trying to to have big theatre sound just want to sound better than the tv speakers and to to enjoy building them. I’m only going for a 2.0 stereo setup using a Topping TP60 amp.
So the speakers I will be using are an odd choice.. but they are what I have and I’m on a budget so they are what I’ll be using. Actually they were not cheap but purchased them new many years and have only tested them. They are MB Quart PVF 213 car speakers. They sound awesome in a car but I don’t know what they would be like in an enclosure, and I have no idea what is the safest way to go about it for a decent sound (I’m not an audiophile btw).
I don’t have all the parameters to calculate enclosure size but this is the info I do have:
Power handling: 50-110watts
Impedance: 4ohm
Frequency response: 52-32.000hz
Crossover frequency: 2.900hz
Tweeter: 40mm titanium
Woofer: 13cm/5.25inch polypropylene
Any advice as to what kind of enclosure might be suitable for the speakers and what kind of volume to go with?
Cheers
Impedance: 4ohm
Cheers
Parameters here:
http://www.audiodesign.de/downloads/testberichte2010/PVI_Series.pdf
Qts of .72 probably best in a sealed cab, let me do a quick sim....
It's cardboard box time! Without parameters we are guessing, but car speakers are usually high-q.
We don't know how high, so try a few boxes, a quarter to a whole cubic foot. The smallest that isn't boomy, and you've got the range to build your box. Boxes, duct tape, and a knife. Sounds like a crime scene! Have fun.
somewhere between 10-15 Litres tuned to 55Hz seems best, you'll get a n F3 ~ 47Hz
Smaller, the low end drops of by a couple of dB; larger, there's a peak at ~53Hz
PeteMcK to the rescue! Go smaller for louder, or bigger if you're not into explosion-laced movies, you can adjust that tweeter once you have them built, that spike works in a car because you are not on-axis, but you'll manage.
PeteMcK thank you so much for that information!!!! Helps so much, I really did not want to guess.
boswald thanks for your help. Can you please eleborate what you mean by smaller for lauder? I watch all kinds of movies
So how do I tune it? Please excuse my ignorance..
Car speakers are optimized to work in a car... and since the domestic environment is very different they don't work well at home. They are optimized to work in a sealed infinite baffle enclosure, and rely on the small internal volume of the car as a boost for bass frequencies.
IMHO, if you want to use them my preferred option would be a small sealed box (5L), for a -6dB point at around 80Hz, a sub would be perfect for a full-range sound. The 10-15L vented enclosure tuned to 55Hz is a one-note bass speaker, much better a 10L box tuned to 75Hz, it is flat from 75Hz to 150Hz and some 3dB louder than 350Hz, that could act as a partial baffle step compensation (-6dB point at 60Hz).
Ralf
Ralf
re:'So how do I tune it?' - with a length of pipe
if your pipe is 50mm Internal Diameter,to tune to 55Hz, use 15.5 Cm in 10L, 12.4 Cm in 12L, 9.2 Cm in 15 L
(Google 'Helmholtz Resonator")
Ok so I’ve looked at a few online calculators and done some research but still a little confused. I have in person saying it might be best to tune to 55hz and another saying that 75hz would be preferable. Which one is best and how do they compare?
I will probably use a 10L enclosure as I don’t eat the speakers to be large and I have found a calculator to tell me port dimensions. I’m just not sure what the ideal Hz I should be tuning to.
I now have more info regarding my drivers thanks to PeteMcK
5.25inch diameter
4 ohm
Fs 98.9
Qms 3.21
Qes 0.93
Qts 0.72
Vas 3.0
30-150watts
5.25inch diameter
4 ohm
Fs 98.9
Qms 3.21
Qes 0.93
Qts 0.72
Vas 3.0
30-150watts
if you want lower bass, tune lower, if that's not important to you, tune higher....
If you tune low, you always have the option to close off the port (stuff a dead cat in it, or what ever you have lying around), and try it both ways. Closing off the port will be similar to tuning high in this case....
- Enclosure ‘safe?’ Size for 5.25inch driver? Newbie
