enclosure materials.
I was wondering if anyone had used plate steel to construct a subwoofer enclosure? I would think that by using 3/8"-1/2" plate steel the structural rigidity would be the best that one could get, especially after welding some bracing inside the box. I would also think that the resonant frequency would be quite low, if there was any at all?
Has anyone built a box from steel, welding the joints ect? I realize that a box like this would be quite heavy, but wouldn't this be the ideal material?
I haven't built a box from steel, but it should be very good. you do not need it that thick. What you want is stiff, and braced such that it has a high resonance. If any (potential) panel resonance is well above the sub's pass-band it will never get excited, which makes it as thou you have a resonance free structure.
Do a search for GM's posts on the subject to get a better idea of a sensible thickness.
dave
As you know audio is all about compromises. The less compromise, the better the outcome. So could you build a 2000lb subwoofer that needs to be moved with machinery? Sure. For what application? Is it worth it? (by the way my welding table is 3/4" thick old road plate...6'x4' or so. It's a pain to move. I can't even imagine constructing a braced (I beam bracing?) subwoofer enclosure out of it!!)
Dakkon
I would not recommend steel for an enclosure as it can transmit energy - ie vibrations.
Concrete and ceramics do not have any tensile strength ( or very little tensile strength ) and therefore can not transmit energy.
Don
