Enclosure Gurus
I'm working on an enclosure for the following woofer and would like your input.
f(s) = 34.99 Hz
Q(ms) = 5.281
V(as) = 30.15 liters (1.065 cubic feet)
n(0) = 0.35 %
M(ms) = 17.67 grams
R(e) = 6.46 Ohms
Q(es) = 0.352
SPL = 87.54 dB SPL 1W/1m
C(ms) = 1.17 mm/N
Piston Diameter = 131.3 mm
Z(max) = 103.39 Ohms
Q(ts) = 0.330
L(e) = 0.135 mH at 10kHz
SPL = 88.47 dB SPL 2.83 Vrms
BL = 8.44
I've been working with UniBox.
No of ports 1
Inside port dia. 6.38 cm
Port area 31.97 cm2
Port end correction 0.519
Standard Design
Vb 19.6 l
Fb 40.00 Hz
F3 42.30 Hz
Port min dia. 2.01 cm
Port length 27.43 cm
Design by Vb, Fb and Q
Physical Vb 33.0 l
Absorption, Qa 5
Leakage, Ql 50
Port, Qp 140
Alpha, a 0.754
Vb 40.0 l
Fb 36.00 Hz
F3 35.32 Hz
Response peak 0.00 dB
Peak at none
Port min dia. 5.16 cm
Port length 15.29 cm
Port 1. resonance 932 Hz
