EnABL Processes
john k... said:
Also, another reason I decided to reject the offer to listen is that I don't want my objective think derailed by a subjective observation. I don't want to be caught up trying to figure out what is the cause of what ever I might hear. I rather spend the time trying to understand the mechanism behind how a change might occur.
I like that approach.
Hi all. Still lurking around this thread...
Thanks John for the diagrams... I think that I can almost understand what you are suggesting here albiet in a probably superficial manner. Let me demonstrate the shallowness of my knowledge with a couple of questions.
1. Am I right in saying that Bud's hypothesis was that the sound wave being "altered" is a surface wave, i.e. In the air just in front of the cone, and that John is refferring to a wave being transmitted within the cone material?
2. Am I right in saying that in Johns model, the frequencies are being altered by the pattern resulting in a mutitude of "more random" "corrupted" frequencies being emanated from the speaker (at higher, perhaps less audible fequencies) instead of fewer less random "corrupted" frequencies in the standard driver?
3. Am I totally wrong in thinking that in the enabled driver in Johns model the wider range of frequencies will be of smaller amplitudes at each frequency point you measure?
Please dont shoot me down if I am getting the wrong end of the stick here, I am just trying to get my head around the debate.
Blair
john k... said:
But this isn’t a matter of height of the pattern. This is about the transverse waves in the cone. They could potentially be reflected because the effective cone properties change at the enable patters. A change in effective density, or stiffness would mean that the wave propagation through this region would have to be different. This would result in some type of reflection back from where the wave came from.
Because of the increased stiffness at the pattern blocks, is it possible that it creates a type of "stalling" of the transverse waves travelling from the voice coil (in the direction of the surround) through the cone as they meet a resistance due to the density/stiffness change?
If the pattern reflected a significant portion of the energy then the wave from the VC would never be able to enter the cone proper. If some how the wave got past the inner pattern and was reflected back from the outer layer then very little energy would reach and be dissipated in the surround. If the wave passed through the outer pattern with little reflection back into the cone, and then the wave reflected from the surround was somehow blocked form re-entering the cone at the outer layer then the cone proper would be void of standing waves, and the waves trapped between the outer pattern and the surround would be rapidly dissipated by the surround. The thing is that the pattern can not behave as a "check valve" because waves don't carry history with them in the sense that they don't know where the came from and they don't see what is ahead of them. Whether they hit the pattern from the left or right they see the same discontinuity in properties and react the same way. All of these effects would result in significant differences in the frequency response, particularly with regard to the resonances observed at breakup.
Gotcha. I had to re-read that a few times to properly visualize what you're saying.
I am having trouble figuring it out though.....there seems to be (in my mind) a conflict of what the pattern blocks could be doing (on the one hand) that they aren't doing (on the other hand).
If there were only the outer set of pattern blocks......but there are an inner set as well, so wouldn't there be a bunching up at the first set of blocks?......a heavy concentration of waves and reflections?
But couldn't the inner and outer patterns be simply damping the cone?
Ok, now I think it's too early in the morning for me to see this clearly now...
Cheers
John K,
I have these same thoughts, though at a slightly less rigorous level, and have been thinking about them since first encountering bending wave theory. Two more things to add.
The transverse waves do have a form of memory, in that they have a vector. This does not alter their activities, obviously, but may have relevance to their initial traverse and potential re traverse at either end of the cone.
Second is to consider how the transverse waves are affected by their placement on a dome. Placement pattern is the same regardless of whether the dome is attached to a cone or is free standing.
I bring this up now, to point out the interactive nature between cone and dome, in a typical cone driver. The amount of gloss coat, used in conjunction with the overall patterns, will determine how much energy, above 1 kHz or so, is emitted as a "sweet spot" on axis. This is a secondary question, while investigating what the pattern may be doing, but it does provide a precursor and you should keep your thought processes open to it.
I do want to point out that just this amount of discussion was utterly heretical 30 years ago. I still do not find many professionals, in the field of speaker design, who utilize the notion of transverse waves being an important portion of a drivers output. Hence the continued march toward perfect piston performance, with the "break up mode" that transverse waves eventually bring about, being shunned as the uncontrolled event it is.
Just so everyone knows, I do approve of where this discussion is going and I agree with John about not coloring his thoughts with listening to the behavior of a treated driver. Hopefully your investigations and thoughts will bear more fruit than mine did, when I thought my way through these questions and eventually ended up with boundary layers.
The goad at the time was the gross difference in audible performance between the then state of the art untreated driver, and it's performance when treated. This situation has improved over the years, through materials science, but the difference is still great enough to force your thoughts into desperate measures, to explain that difference and the seeming insignificance of the method used to cause it.
Bud
Re: I struggle with this, too
Ed LaFontaine said:
...the energy from the voice coil enters the cone...the energy travels through the cone (ok so far?)...what influences (determines) the portion of the energy that is radiated from the cone & the portion of the energy that remains in the cone?
The power radiated is given by the real part of the radiation impedance times the surface velocity of the cone squared. The radiation impedance is a function of the fluid into which the driver is radiating (air). So once again we see that it all comes down to how the surface of the cone moves.
BudP said:
John K,
My point is that for a wave traveling in a given direction with given amplitude how the wave got there isn't relevant.
Sorry I don't follow.
John K,
Sorry, This should have read:
Second is to consider how the transverse waves moving through a dome are affected by the placement of the block patterns on the dome. Placement pattern is the same regardless of whether the dome is attached to a cone or is free standing.
Bud
john k... said:
Ok, I have constructed some simple wave diagrams for a one dimensional radial slice through a driver cone for untreated and Enabled drivers. They represent a simplification of the real case, but the relevant physics is presented.
In this figure the cut of the driver is at the upper left. The center line is though the center of the VC. The cone extends from the VC to the surround with a radial length R, A transverse wave is initiated at the VC/cone interface and propagates outward to the surround where it is in part reflected back into the cone and in part transmitted to the surround. The reflect wave then travels back to the VC where it is again reflected back towards the surround. Each time the wave in the cone is reflected energy must be conserved so energy transmitted to the surround or VC is lost and results in a reduction in the amplitude of the wave.
Directly to the right is the wave diagram for this process. The cone VC junction is at the origin. The radial distance along the cone surface is the horizontal axis and time is the vertical axis. Assuming the wave in the cone travels at a velocity C1, then it take a finite amount of time for the wave to reach radial positions on the cone away form the origin. The line extending from the origin upward to the right represents the propagation of the original wave. If you go to some radial location on the cone, for example r1, and draw a vertical line to point of intersection with the line of propagation of the original wave, then a horizontal line back the vertical axis indicates the time at which the wave reaches that radial location. The further out in r the longer the time.
The line starting at the surround and sloping upward to the left represents the first reflection of the original wave from the surround. The small line sloping upward to the right at this point is the component of the wave transmitted to the surround. The next line, sloping upward to the right is the reflection from the VC/cone junction of the wave reflected from the surround. This pattern would continue until the wave energy is completely dissipated.
If we draw vertical lines at different radial locations, r1, r2, r3, the points where each vertical line crosses the wave propagation paths indicates the time when each wave or reflected wave reaches that radial position. Since the wave remains unaltered except for amplitude, we can think of each crossing as resulting in an imaginary source radiating into the air which is identical to the original wave but with a scaled amplitude and delayed by the time it takes for the wave to arrive at that radial location.
If the speed of sound in air is C, then the distance a wave travels from the cone surface towards a listener (on axis) over a time T is C x (T-t). From this we can produce the second plot which shows the distance the sound from each imaginary source travels towards the listener as a function of radial position.
We can collapse this information into a time train by dividing by computed distances by the speed of sound in air as shown at the bottom. This time train represents the arrival times of the information radiated by each imaginary source. In reality we would have an infinite number of such sources between the cone/VC junction and the surround, and the time train of the signal would be a continuous function of time, but the original signal would still be smeared in time unless the cone were reflection free and the time required to the wave in the cone to traverse the distance from VC to surround was much less than 1/f, where f is the frequency being radiated.
Now look at what could happen when an Enable treatment is made. The figure below considers this case:
The black lines represent the wave paths resulting from the reflections of the original wave from the surround and the VC. The red lines represent (some of) the additional reflections/transmissions due to the Enable pattern. I won't bother going into any arguments as to why the imaginary sources associated with the enable generated reflections/transmission must be much lower in amplitude than those associated with the original waves other than to say that it should be obvious that if there were of significant magnitude then the measured frequency response of the driver would necessarily be very different. I'm more than happy to go into this if someone wants to honestly discuss it, but I won't engage hand waving arguments as to why it ain't so.
The problem with this theory is that the patterns must have sufficient weight to be able to reflect waves as mentioned, otherwise they are floating on the wave instead of acting as a wall. Additionally, if it started to have effect, as a floating device, the relationship between the ploat and the wave would be such that the wavelength would have to be so small that it would be probably in the range of 40KHz and up.
No. The reflection is not due to the mass directly, reflections occur if there is an inhomogeneity in the cone, to include any material in contact with the cone. Applying a material that is different than the cone itself not only provides another path through which part of the wave will travel, but it also stiffens that area of the cone such that it is an inhomogeneity and will reflect, no different than for the surround. It's a junction between two different materials and if it is not a perfect impedance match such that there is total damping of the wave, some of the energy is going to reflect. Keep in mind that this is a transverse wave that creates the compression wave in the air via the cone [I/surface] to air interface, whatever that surface is.
Consider that if what you said were true, then spraying the entire surface with a very thin layer of some material, any material, would have no effect whatsoever. We know that this is not the case.
Dave
OK, question. If I follow this, the transverse wave/movement of the cone surface interacting with the EnABL pattern is the theory here. Not boundary layer, not anything once the sound wave impulse leaves the surface of the cone (sorry if my terminology isn't quite accurate here...). My question is, wouldn't the magnitude of this surface wave be greatly influenced by the material of the cone? I.e. if the cone was made of metal or some similarly rigid material, wouldn't we expect this transverse wave to be smaller?
OK, I obviously don't know the answer to that, but if it is yes, and the assumption is that EnABL interacts with this wave and not at any other level, then wouldn't if follow that EnABLing such rigid cones would have MUCH less effect than doing so to paper or similar cones? And what would be the effect on treated cones such as Planet10 uses? Has anyone treated such rigid cones (if my assumption about rigidity even holds...), and have those shown similar effects?
Thanks for humoring my beginner questions,
Carl
Carl, Maybe soongsc will respond. His efforts have included metal domes and yes, there is a recognition that metal domes respond differently to the EnABL treatment.
Thanks for the dialog and sketches John...
By john K: I'm more than happy to go into this if someone wants to honestly discuss it, but I won't engage hand waving arguments as to why it ain't so.
Agreed
Further agreed that the EnABL bands are producing reflections/transmissions.
My curiosity becomes focussed on the qualities of those transmissions, particularly in comparison with those transmissions from the junction of the VC and/or surround with the cone.
CarlP,
I will be looking into this very question over the coming week. Soongsc did indeed apply EnABL to a metal cone, the same I will be working with, a Jordon JX92S cone and dome.
To date, application to aluminum center domes, polycarbonate domes and leaf tweeters, and aluminum ribbon ends have all provided the same type of change, with downward going detail and dynamic color increasing, and, also allowing extended SPL before onset of audible distortion, with a much more benign character to that onset. These characteristics are found in all but one driver I have treated to date.
Soongsc did not actually listen to his test cone. Like John K, he wanted to be free of subjective evaluations, while he explored the patterns. He has provided some valuable test data and some controversial test data to this thread.
In addition he has used EnABL as a spring board to find other patterns and sets of shapes that, based upon CSD plots he has provided, move well beyond what EnABL provides. I have not heard these devices and don't actually ever expect to.
However, I commend his efforts and hope that others can also use EnABL for their interests. Even if that is just to enjoy more musical value from your drivers than was available before, while awaiting professional applications, after suitable research has occurred.
Bud
Hmmm. The Jordan is exactly what I had in mind. However, having read over their site,
Simply put, for low frequency sound radiation, the air load demands a relatively large rigid cone whereas for high frequencies a progressive reduction in cone area and mass is required. Loudspeaker cones tend to mirror these requirements in that they are substantially rigid at low frequencies but high frequency flexing progressively reduces the effective area and mass...JORDAN cones, accurately profiled from fine gauge light metal foils, have the ability to resolve the low level detail that imparts the 'breath of life' into sound which would otherwise be just technically good.
it seems they specifically design their drivers to encourage this kind of transverse wave for upper frequencies (OK, so that's not the intent, but it would seem to be the effect of their thin metal foil approach). Therefore, I'm not sure that driver provides the stiffness I was thinking about.
The driver I'm thinking about might not be any good at sound reproduction, but the idea is that it would dampen the transverse wave and therefore the effect of EnABL. The idea would be to find such a driver and EnABL it for blind comparisons to see if the rigid cone has less effect due to EnABL than less rigid drivers. If there is a similar effect for the listener, then I'd wonder if it was time to bark up another tree...
Carl
Carl
I do not know of any driver that is as rigid as you seem to want to look at. I have some polypropylene woofers and unused mid woofers that are very rigid. Made by DynaVox. The woofers took quite a large amount of gloss to get them to work as well as the Vifa 3 inch mid dome they are paired with. Crossover is at 800 Hz.
The patterns alone made them clearer, but the effective transient signal response was, in their untreated and EnABL patterned state, not a match for the Vifa dome.
They are now, but just. Audibly they miss the upper bass edge to some musical instruments, but lower crossover points compromise the mid range too much. Just another trade off, but both drivers are equally detailed, so it is a bearable one.
Perhaps other readers and lurkers can suggest some appropriate devices.
Bud
I would be very interested in the driver Bud says doesn't respond to EnABL. There might be a few answers there.
As to the rigid driver: if one imagines some kind of limit such as a perfectly rigid driver we have a piston (most folks' idea of a perfect driver ;-) ). I cannot imagine, right or wrong, that EnABL would have much effect on that. To find an actual one, one might have to look at long-throw subwoofers. Unfortunately these would have much reduced response in the frequency ranges of interest (I suppose). Or, damp the *c@3 out of a driver with some material that doesn't become 100% firm such as sorbothane.
It might not have much purpose though, I fear. And you won't have much use for it later.
JacquesToo,
Electro Voice TH350 with phenolic diaphragm. I treated all available surfaces of pole piece, dome, compression chamber, phase matching tunnels, phase plug, horn throat and flare edges. I had one other, untreated, TH350 for a reference, with the same age and mfg. of the dome driver.
Before treatment they were closely balanced, both very sweet, dynamic and as colorful in high frequencies as I had heard to that point. Afterwards they were as identical as they had been, before I treated one of them. No audible difference, plus or minus.
Bud
Assumming for the moment that this is indeed a potential mechanism, could it be an analog to the dither insterted into a digital signal in a CD player?
dave
Dave
I think my original post already answers the issue you have addressed in the first paragraph.
In the second paragraph, whether or not spraying material on the surface will make a difference or not depends on the actual application. I have two 6.5" metal cone drivers, one with sprayed material and one without. Both did not accomplish what I was looking for. There are more material characteristic properties involved than you think.
