One of the vendors I deal with does not check for items being "in-stock" when I place the order. It is only when the shipment arrives that I discover the back-order.
I had to order a single pen tip from another source as a result of this. They should be here this week.
As this has happened more than once now...I believe I need to review responsibilities and expectations with them...
Hello Ed ,in the market for your EnABL kit , Does application apply and work on larger drivers 8 0r 10 inch, in the process of building the frugal horn on which will probably use the fe 126 en , being unemployed the last 7 months will have to wait till next week to purchase .Thanks kevin
Hello Kevin,
The process does work on larger drivers. Bear in mind, full-rangers have gotten the most effort to develop. I would check out Planet 10's treatment patterns for the fe 126 en.
Materials are in stock. No hurry. My best wishes to you for getting back to work. I know what that is like...
Dear Ed are there instructions that come with your kit , or somewhere on this thread that i can find what to apply in what order, Thanks Kevin, Ps did find ring layouts for audio nirvanas and the FE126 drivers
Hi Kevin,
I don't include directions. There are answers to some questions included in the first ~40 or so posts to this thread. Also, you may search topic "enabl" along with user name "BudP" who started us all down this path.
http://www.diyaudio.com/forums/multi-way/119677-enabl-technical-discussion.html
is the beginning of a thread marking a "fork in the road"...links back to the origins and a consolidation for moving forward.
That's great that they arrived. My tracking didn't indicate they would be delivered until tomorrow.
Check the first ~40 post in this thread for links to get you started. You have some "homework" to do. BudP & Planet10 are the guys who I would lean on for advice, when the time comes.
