Repaired driver board for outputs. Had good low side output gate drive.
I installed only 1 transistor (used ones for testing purpose) for each output bank to test if amplifier is working.
Powered up amplifier and it was working - produced both h/l drives and got good audio output.
I accidentally removed remote wire and right after that i installed it back - and after remote was applied it blew one bank of high side output transistors.
Do I miss some problem as it blew when i fast reconnected remote wire?
Or is just because there wasnt all output transistors installed and gates couldnt discharge fast enough?
Image with driveboard with pulled vias is not mine - is just from the google to understand which one amplifier uses.
![emphaser_87014.jpg](https://bilder.hifi-forum.de/max/489801/emphaser_87014.jpg)
![pwm-15000d-emphaser.jpg](https://www.disotech.it/images/pwm-15000d-emphaser.jpg)
Is the delay startup working? The rail voltage should come up before the oscillation starts. Something like the following video capture shows (sorry for the quality).
http://www.bcae1.com/temp/ampstartup01.mkv
You may consider using a low-voltage supply to help prevent damaging parts. Start reading here:
4000.1
4000.1
Can I use low side (without fets installed)?Is the delay startup working? The rail voltage should come up before the oscillation starts. Something like the following video capture shows (sorry for the quality).
Well i blew up another set of "test" fets.
Repalced all irs21844 and installed 1 fet per group.
I was checking oscillation - it started a bit earlier than rail voltage was stabilized.
Had good high side drive. Rail voltage was stabilized on scope. I was triggering remote on and off and it didnt blew - but i didnt wait till output relays engage. I found it it blew only after i reconnected remote after relays were engaged. Waited till relays engage, disconnect remote, reconnected it back and blew totally open output fets.
You may want to use low voltage during troubleshooting.
https://www.diyaudio.com/forums/car-audio/319174-4000-1-a-7.html#post5492949
I don't understand post #4.
