Emergency! Please help me choose 2SA1216/2SC2922 or 2SA1295/ 2SC3264 transistor
Dear every one!
Please tell me the difference in the transistor 2SA1216/2SC2922 and 2SA1295/ 2SC3264. I want to use them to DIY some high quality amplifier. In the datasheet, they seem identical except for differences in voltage, 2SA1295/3264 have withstand voltages ( max 230Volt ) greater than 2SA1216/2922 ( max 180Volt ), but my amplifier running under +/-70VDC. For the best performance please guide me choose the one?
Is the 2SA1295/3264 are low price of 2SA1216/2922 version?
I will oder from Profusionplc: 2SA1216Y
Technical Specification: please see picture
Thanks and best regards
Good day!
Hey don't dismiss their thermal resistant.
A1295 has a bit better thermal resistant than A1216. Also there already A1494 with much better thermal resistant. It is SANKEN superiority. It affect greatly on its reliability.
The rotel works at 95volts rails.
the rotel works with a VI limmiter and the 49810 with a baker clamp i can't tell which is better but since i am a classic guy i will choose vi limmiter
o yes something i ve missed ...i was told that the best way to work this ic is to supply it with a few volts more than the output stage makes sense but will cause construction issues
