pop sound from speaker when i turn off car, the remote wire i'm using is from the accessory (ACC) because the factory headunit doesn't have a remote out i probed all the leads on the back to no luck so my only option was to use the acc or add a turn on switch. is there a way to remove this pop sound if the rca isn't plugged in it doesn't make that pop sound it only makes it from the rear speaker. it might be because of a cheapy line out converter i'm using for the rear line out converter because this isn't happening to the front line out converter.
i don't have a turn on pop only a turn off pop from using the acc for the remote wire because the stock head unit doesn't have a remote out i tried probing for it but no luck. is there anything i can do to get rid of that pop when turning off car
Good question Mote. Alot of amps have special circuitry to ensure "soft" turn on and turn off to eliminate popping. Maybe it is an internal problem with the amp???
