Elektor amplifer
I am building one. The power supply requires 45v-0-45v 5A toroidal transformers (according to parts list) The main line fuse is rated at 4A (F2) (according to parts list)
To calculate VA rating of the transformer:
45V+45V-1V=89V 4AX89V=356VA. My question is why 5A rating for the transformer in the parts list? Should the calculation be: 5AX89V=445VA
I am building one. The power supply requires 45v-0-45v 5A toroidal transformers (according to parts list) The main line fuse is rated at 4A (F2)....
The line fuse is on the 240V side. The "5A" is on the 90V secondary. In a simpler world we would expect the low volt side to be 2.6 times more current than the line side.
I can't read that PDF.
*IF* this is two times 200 Watts audio output, then it is at least 660 Watts of DC. The AC/DC conversion needs about a 1.2X correction Watts DC to VA AC. So for long term FULL-power operation the transformer "should" be 750VA at least. And double that for hard work in 4 Ohms, 1500VA. Which would be 6 Amps, but this extreme is so unlikely that 5A is fine.
If you use the amp for speech/music, it will never linger at 200 Watt/channel long enough to bother the transformer. In hi-fi you can often use a much small transformer than FULL-power computations suggest. Since I doubt reliability at 4r/ch, maybe even 300VA-400VA.
Elektor LFA & LFA_A
Elektors LFA versions 1988 and 1991 Class A
LFA
I found some pictures from the LFA i built. But you can save money and use the 2SK170BL or the2SK170V.
Reactions: sonicles
Nothing wrong with old amp designs, even What HiFi put an original Cyrus One up against the new one, they both still have their place in the world and sound good. Some old design are better than new offerings, and Elektor have published some interesting designs over the years.
Don't be afraid to use equivalent devices. Fairchild have good equivalent output transistors like the FJL4215 and FJL4315, also sold as the new 2SC5200 and 2SA1943 parts.
Mouser stocks a range of dual jfet parts. I've substituted the through hole types with 2SK2145 SMD parts before as they are cheap. But you can get parts like the IFN401 or IFN5565 or 2N3958 and many others. They are expensive but they are unique parts these days.
