Elekit tube set options
ELROG 300B + Telefunken ECC83X 1 + ECC82 X 2 $1,950
ELROG 300B + Telefunken ECC83X 1 + Seimens ECC82 X2 $1,650
ACME 300B + Telefunken ECC83 X 1 + Seimens ECC82 X2 $1,200
ACME 300B + WE5755 + RCA 12AU7 X 2 (clear Top) $875
Psavne WE300B + Telefunken ECC83 X 1 + Seimens ECC82 X2 $975
Psavne WE300B + WE5755 + RCA 12AU7 X 2 (clear Top) $750
LINLAI/COSSOR Black Plate 300B (MADE BY LINLAI)+ WE5755 + RCA 12AU7 X 2 (clear Top) $285.
LINLAI WE300B (MADE BY LINLAI) WE5755 + RCA 12AU7 X 2 (clear Top) $625
ACME 300B, PSAVNE WE300 & NS WE300B
Individual Tube
300B Tube per pair
ELROG 300B/$1,475.00
ACME 300B/$ 875.00
Psvane WE300B/$775.00
COSSOR Black Plate 300B/$195 (MADE BY LINLAI))
COSSOR WE300B/$495 (MADE BY LINLAI)
WE5755 with Adapter $45 (with getter)
WE5775 + RCA Clear TOP
RCA clear top 12AU7 $45
Gold Lion (B749 X 2 + B759 X 1) $100
EH Gold ECC83 X 1 + ECC82X 2 $60
Coupling Caps
Mundorf EVO Supreme Silver Gold 0.1 X 4 $150
V-Cap ODAM (Oil Damped Advanced Metalized) 0.1 X 4 $200
V-Cap CuTF Copper Foil and Fluoropolymer Film 0.1 x 4 $380
Carbon Resistor
Takman 2% $65
Volume Pot
TKD 2CP601S with conversion Kit $65
Hi Victor,
Do you sell Telefunken ECC83 individually?
Regarding the coupling caps, are they the upgrade of C103, C104, C203, and C204? But those are 0.22uF 400V cap. How do these caps make sound better, smoother or more lower noise floor?
Ken
Hi Ken
I only sell ECC83 with ELROG + TU-8600S
There are 4 0.1X coupling caps in TU-8600S. I have V-cap (copper or ODAM) or Mundorf SESG in stock
If you are in Hong Kong, I have a demo amp in WIWI Tube. You can order caps from WIWI
NS /COSSOR Black Plate 300B
Victor,
I have been listening to the Black for a few days now and they sound perfect! The sound signature is somewhere between a Gold Lion 300b and a JJ 300b. There is a bit more bass than the Gold lion, but not as much as the JJ. The mids and highs are almost the same as the gold lion.
construction feels solid, Thick glass is used and I can tell a lot of care has gone into the black plate, The tube elements are aligned almost identically between both tubes. even the labeling is on the same side on both tubes. JJ and gold lion tend to be pretty random in respect to that.
Both black plates tested within 1% plate current on my freshly calibrated and restored Hickok kS-15874-L2.
Another thing I noticed is that the heater has a different glow to that of the Gold Lion and JJ. it has more of an orange glow. Also, when I turn i'f my Tu-8600 the black plates are silent like the JJ as the tube cools off. unlike the Gold lion that can sound like an aluminum can getting crunched slowly, The heater on those contract too much, that's probably why I've had 3 pairs of Gold Lion fail in the same way.
Anyways, the black plates are my new favorite 300b! and at the price they are hard to beat. I'll be tracking the life of the tubes with my tester to see how they compare against the JJ, which have almost 2500 hours and tested almost within 10% pate current of the new black plate. In comparison the Gold lion with about 1500 hours tested within 60% and the Gold lion with the bad heater tested within 30%.
Thank you for offering a wide range of 300b! I probably would have never heard of these if it weren't for you.
Thank you!
