Elekit 870R
Optional Parts
Optional Speaker
Here is the wonderful comment from Audioasylum
Bench tests and listening impressions - 4season - VK Music - Elekit & Triode Japan Forum
VK Music - Elekit & Triode Japan Forum: Building the TU-870R (photos) by 4season
Amp/Preamp Asylum: RE: (strong)REVIEW: Elekit TU-873LE II Amplifier (Tube)(/strong) by geraldm121
Amp/Preamp Asylum: RE: Building My FIrst Kit...What Fun by geraldm121
Features:
This is a single stereo power amplifier using the 6BM8 vacuum tube that has a five triode for power amplification and a triode for amplified voltage. Assembly is easy. Anyone can follow the printed circuit board and obtain the same result. For this reason, you do not need to know the details of wiring and other technical details to assemble a vacuum tube.
This amplifier installed with advanced "R-core transformer" as a power transformer that enables clear tone quality. To improve transient characteristics.
Specification:
Vacuum tube : 6BM8 x2
Rated output : 2W + 2W(8Ω)
Rated input : 600mV
Input resistance : 45kΩ
Residual noise : 80μV(IEC WEIGHTING)
S/N ratio : 94dB(IEC WEIGHTING)
Frequency response : 26~37,000Hz
Power voltage : AC120V 50 / 60Hz
Power consumption : 35W
Dimension : W130 X H130 X D263mm (including projections)
Weight : 2.9kg
Input terminal : Line x 2 (RCA pin jack)
Fuse : 1A
VKMusic.ca Home page
Price $315
Optional Parts
Optional Speaker
Features:
Specification:
Rated input : 600mV
Weight : 2.9kg
Fuse : 1A
Price $315
didn't realize Elekit could be so affordable
Hm:
a cd player ($390.00), an amp ($315) and some DIY speakers (maybe not the Elekit) and the pre-amp ($345.00)
LP ready , all tube system w/cd player ($1060 w/o tax). I like 6BM8 tubes, and the Japanese seem to as well. Not sure of the circuit, but must be similar to the SE84C from Decware
Hm:
