Elekit TU-8600 300B SET AMP
YOU asked for it. YOU got it!!
We listened to your requests, and the highly regarded ELEKIT designer, Mr. Fujita, has taken these requests into consideration. We are happy to present to you the release of the newly designed 300B amp in late September 2017.
The new 300B amp has a lot more improvements from its predecessor (TU-8300R).
The noise level of TU-8600 is as low as 1/10 of the TU-8300R. Amazing design..
 300B SE Tube Amplifier Kit
 Tubes : 300Bx2, 12AX7x1, 12AU7x2 *Tubes are not included!
 Rated output : 9.2W + 9.2W (THD 10%)
 Rated input : 320mV
 Residual noise : 36µV (IHF-A)
 Frequency response : 7Hz-40kHz (3dB)
 Input impedance : 50k
 Output impedance : 4-6.30, 8-160 (Select by the switch on the rear)
 Input terminal : LINE x 1
 Output terminal : Speaker terminal
 Gold-plated screw terminal (banana plug usable)
 Power voltage : AC100/200V 50/60Hz (3P inlet)
 Power consumption : 90W
 Dimensions : W385xH217xD325mm (excl. projections)
 Weight : Approx. 12.6kg (excl. power cord)
OPTIONAL LUNDAHL LL2770 OPT
flags_1
