Ok nobody seems to be able to answer this. On my head unit the output for each channel is L-3.93V and R-3.93V feeding each channel into a mono amplifier I know the signals are combined but are the voltages also? Do I add them together to get 7.86V ? I know if I disconnect one side it get quieter so it is cutting voltage. Any help would be greatly appreciated, trying to set the gain input level properly (1V, 2V, 4V, 8V, 16V) on mt Kicker sx1250.1's. Polo..🙂
Most automotive mono amps add the L and R inputs together to form the output
To set the output you really shouldn't go by the markings on the amp though, they're very unreliable
http://www.resnet.trinity.edu/areynol1/gain.htm
It is the input gain level range not the gain itself. So should I add the voltage of both channels? Polo..
Input level, input sensitivity and gain are all different names for the same thing, I'm not sure what you're asking.
Ok my amp is digital, in the beginning of the menu it asks what input gain level setting. I need to meaure the appropriate voltage which I did then select the desired setting, I will either select the 8V or 4 V setting. After the gain range is set I can accurately go ahead and adjust the amplifier gain. This has a line driver and digital signal processor built in. Range setting and gain level are two different things on this amp. All I need to know if the voltages combine 3.93+3.93V= 7.86V? Polo...
No,Use the 4V setting.
Ok, or should I overdrive it to gain headroom? If I set it at a lower setting like 4, 2, or 1V it will overdrive the signal (line driver) and I am able to run the gain at 1/3. Polo.
PS- thanks for your guys help..
- General Interest
- Car Audio
- Electronics Gurus.
