Hi, there,
I have been used Electronic workbench for quite sometime now, and unfortunately, the copy I have is fairly outdated (from the mid 1990s), and it doesn't have a lot of parts.
questions:
1) what software are you using? their pros and cons?
2) if i am goin to stick with mine (5.0c), where I can get new parts library?
Thanks in advance.
questions:
Thanks in advance.
I'm using Eagle Lite, the freeware form of Eagle. It's got the occasional bug and its PC board layout autorouter is semi-comatose, but otherwise it gets the job done. Plus it can export plot files in several formats, which comes in handy if having a board professionally produced. Comes with a decent selection of parts and its editor can be used to build more.
You can download it from here, and if you wanna drop the $200 you can get the standard version that allows more signal layers and a larger board area, or $400 for the pro version that has no limits.
oO
oO
PCB software
Hi guys!
Is there a software that can let you draw a schematic and then automatically make a PCB of that schematic?
Thanks,
Jojo
Hi guys!
Thanks,
Jojo
Olle Bard said:does anyone lnow where i can get a national semiconductor lirary for the eagle software?
you may want to check the orcad site. Under "Pspice", there are tons of spice models to download.
I have used Pspice extensively, will be using Protel starting this summer, and heard Simplorer is also excellent.
- Electronics CAD software
