Intructions, as i could find that our forum has a lot of Electrical Enginneers that can help me.
I need some help, form Electricity Enginneers and all experienced guys related the subject.
Electronics lamps burning constantly.
I have one small appartment, 200 meters distant the place i leave that is rented.
The one that rent the appartment is asking some electricall inspection, as lamps are burning too much constantly, and in special in two rooms.
I have not idea about the reason why..... and asking you guys, if someone have an idea about the possible causes.
As i will go to this appartment, to make some inspection visit, i will go with an electrician that also do not know the possible causes...so...i am needing some instructions.
Do you think oxide connections.... faulting switches.... under voltage, spikes?... have some idea...as i want to fix this problem, this is my responsability, as apartment was rented as good to leave, and now presenting problems that have to be fixed.
All instructions or suggestions...or procedure instructions are welcome..as i am feeling alike a blind man walking between two gangs that are figthing and bullets passing near me coming from everywhere...do not know how to fix the problem!!!
Regards,
Carlos
Regards,
Carlos
Poor wiring...someone switched the neutal instead of the hot wire and light bulb is being grounded? A shorted switch is a posibility. Always look for the most obvious first even if it seems easy to overlook.
What excactly are you experiencing. Some lights are brighter in certain rooms and others are dimmer? Sometimes a misbalanced main transformer where the secondary center tap is bad connection to neutral maybe from corrosion, can cause higher voltage on one side and lower on the other and can pop lightbulbs.
lots of moisture in Brazil isn't there?
maybe a switch or wire is bad in a 3 way connection. (2 switches for one light)
Just be sure to use common sense so you don't get hurt
and keep a meter handy.
I once rented an apartment and in playing with my amplifier circuits, noticed that the unloaded transformer secondary voltage was like 6-8volts higer than it used to be.
So this led me to measure the line voltage with my handy dany voltmeter and found the line was about 138V. This was confirmed by others living there by complaints that light bulbs didn't last very long. I notified the utility company and come to find out, the main transformer feed to that apartment complex used to also feed another building that was recently vacant and disconected. So they had to move the tap on the primary to include more turns in the primary to lower the voltage. Who knows, I may have prevented a fire!!
mastertech said:1)i think your lamps are fakes
2)calm down
3)ask an electricity inspector to check wiring
4)good luck
Ha Ha fake lamps...are these the ones made in China beside where they make fake transistors??
audiofan said:1° check for overvoltage
2° check for overheating ( ovrsised bulb in a small shade )
3° check for vibrations ( d'ont rattle a bulb under voltage )
4° cheap bulb
5° instant cooling ( dont spill water on a ligtbulb )
These seem like the only possible reasons to me. Bad wiring means it will work, not work or be dangerous.
The only other possiblity is this unit is on the same circuit as a certain faulty lift.
It would probably be cheaper to give the tenants a box of free globes and rent to unit to blind people in the future.
Greg
(still downloading.....)
anatech said:I just uncovered a box of NOS GE bulbs. They were beside a box of pretested Sylvania flash bulbs. The light is truer than any bulb produced today!
I agree.
Also, have you noticed, salt isn't as salty as it used to be and sugar is not as sweet .
Greg, be free to delete the file...no problem...Guys!...thank you all
Every inform was precious.
Polarity check
Heat analisis
Vibration in the mains frequency...noise result of vibrations
Possibility of fake lamps
Over voltage
Rust and socket corrosion
Interesting Mastertech, corrosion from Sea salt is not reaching that place..it is interesting, now, in front of the sea, i have not this problem...only the five first stages are beeing corroded...maybe the salt suspended is heavy and do not reach my place...no oxide here.... i cannot understand..... do you think they grounded all the iron of the concrete extructure....or maybe some voltage biasing to avoid electrolitic corrosion?... there are some batteries near the main building ground...maybe they are biasing something...no rust...interesting that...and confuses me!...maybe some air dinamics effect of air masses routating when reach the buiding front...glasses also do not have salt over them..i checked using my own tongue...very interesting that!
Thank you all guys that came to cooperate:
Mastertech
Dimitri danyuk
Anatech
Greg
CBS240
Audiofan
MZZJ
All of you with good ideas, and many guys confirming other guys ideas...this is good... the result of many guys are always better than one single one thinking about the subject.
I was thinking to replace all appartment wiring....80 square meters appartment, to replace ao Quick thermal automatic fuses and to order the electrical company a new Consumption Meter.
I lived inside this appartment from 1990 to 1994, and it was nice, but i moved to another one bigger and my Wife's sister (hummm...beautifulll...oh!...oh!...oh!) use it for long time, was rented to her by very small value (well, she deserves...i am sure!)... and she told me called a man to make a revision, and the traditional corruption appeared there.... the man offered her a zero consumption hidden relay....he remove one ceramic plate...made a hole...install an enormous noise "CLAPT" industrial relay and one outlet socket, beeing shorted using a small plug, made the consumption meter stop to run.... i dislike that practice, very common and stupid, as differences of town consumption and real central consumption measurements are of course paid...the real consumption finished beeing divided by all corrupts... foolish those things...we will pay always...they will never loose a single watt...well she did that and we insist that she remove...she made that after 3 monthes of discussions...not so hard discussions..i cannot discuss hard with beautifull woman...my voice will tuning week, week...week...and i normally run form the discussion with beautifull womans...they always win!
But i am afraid of some connection made there!.... in brazil people do not use to melt solder over junctions...are made with some mechanicall tool...some king of wire wrapping...and insulation high voltage and fusion rubber is applied over...the rubber melt and turns a single capsule covering the junction avoiding air and oxide.
The possibility of polarity changed is big...will check that.... termal problems will be verified, and also the presence of noises.... our mains is 220 and 60 hertz...a very good service.... do not fluctuate more than 5 percent...very stable and the electrical instalation is heavy gauge to avoid resistance...cooper wiring five milimeters diameter outside appartment and 3 milimeters diameter inside apartament, after the automatic thermal break in fuses
Dimitri...salyut
Saci pererê is a beautifull children story, made by Monteiro Lobato, Corn that speaked...and a very delicious farmer story.... saci pererê was an young very black and shinning Negro boy, that had a red hat and a pipe...he had not one of the legs, so, he used to run jumping..... good to know you have so big culture Dimitri....you are a culture monster....you may be unhappy, the place you are living have people with expertise in something, but not too much people with general world culture alike you....you may be sad Dimitri... talking alone, to yourself...oh God!
Studed too much.... and something i learn arriving my place, some wrong rules i believed in the past.
I was thinking that in some land, where everybody is blind (not good knowledge people), someone that have a single eye will be the king(because have bigger knowledge and will be apreciated and promoted)....NEGATIVE...real world here is different.....here, the one that know more, are hated..people feel jellows and try to disturb, unstabilize and destroy the one that have special knowledge, because this kind of thing is perceived as an amenace...as something very dangerous!...so:
In some land that everybody is blind...the one that have one single eye will be destructed!
Related tape recorder adjustments and Radio Frequency transmitters repairs and alignment, i used to talk to a tape recorder and to discuss with myself... i was very alone.
regards,
Carlos
Polarity check
Heat analisis
Over voltage
Mastertech
Dimitri danyuk
Anatech
Greg
CBS240
Audiofan
MZZJ
Dimitri...salyut
regards,
Carlos
additional note on 3 phases sytem:
I you have a power distribution in 3 phases Y connected with 4 wires a break in the neutral wire will leave the system unbalanced and from this point volage will rise or fall on a particular load when other load at any point of the system is changed.
If you have single phase distribution ( north américan 120 volts-240 volts system ) a break in the neutral wire will have the same effect
In both cases the sytem will work on a principle similar to a voltage divider instead of keeping a load in parallel with a power source of constant voltage.
Pour ici Monsieur, tout lés choses son americaines... everything here is American
Here, everything is hardly influence in US culture.
Jeans pants, automobiles, Coke, and all stuff....
No,we do not like intervenctions with other countries to protect Democracy...if this is so good as they say...i do not see any need to protect.... as people will run fast to that kind of Government.
The voltage system here is the same as United States, having places with 220 and other with 110 Volts... 2 wires are used...the third is ground made with copper bars deeply inside the ground and with all bars connected one each other.... there are two, one only for atmosferic discharges...other is connected to equipments that need to be grounded.
No, we have not bivolt.... one single return and 120 and 240... the third wire...when used.... is to grounding purposes.
I love USA and all that wonderfull people...the presence was always kind and cooperative...but since Kennedy death, and since the Vietnam...the young people do not apreciate US government, the young guys call U.S. as decadent modern Empire.
No one here agree with U.S. official informs about what happened related Kennedy....i remenber my people crying in the streets...my country stopped to cry for Kennedy.
Thank you...the informs you and others, kindly wrote here, will be very usefull, so, in a matter of 48 hours i will have solution for this problem,,, and two rooms only with that problem....and electronic lamps...i think may be inverted polarity.
regards,
Carlos
regards,
Carlos
Wiring
Hi Carlos
I have had this problem in an old house.
Bulbs died soon and sometime fuses burned.
The problem was in loose wiring and wire that has become hot because of loose wiring. This may be in the fixture itself on a switch or in the electrical box.
If the wire has been hot, (burned insulation or insulation that has been hot) you must replace the bad segment.
An electrician told me that years ago but i have only screwed all wires. Problem was still there!
I have replaced wire segments that have become hot and problem dissapeared.
You may try that after having checked voltage on two phases.
I am not shure at this day that i have understand why wire do that.
Did you notice the avatar? He He !!!.....
Bonjour!
Hi Carlos
Bonjour!
Yes amplifier gurú...i will remove my comments, as i think the U.S. people do not
Apreciate those things Governments use to do.
Anatech, etêz vous au française cotê du Canadá?, est la votre première langue le français?..... c'est trés bonne pour mois, sa qui vous avez un passé latin.... trés bien mon cher ami. Vous êtes le seconde Canadien du langue française qui produit plaisir pour mois, avec bonne conversaccion. N'est pas accident, nous somes tous descendant du ancient Rome.
Anatech, are you living in the French Canadien side?, is your first language the french?.... this is very good for me, because you have a latin root, very good my good friend. You are the second Canadien speaking french language that produces me pleasure, with a good conversation. This is not an accident, we all are have ancestor that came from the Roman Empire.
I will use all the informs you gave me, and i thank you very much for the aid you gave me....now i have many tools to research and to fix fast and easy the problem...this is great...have all this knowledge as reference.
I will go to fix in a matter of 3 hours...i will return results for you all..thanks!
regards,
Carlos
regards,
Carlos
No more problems!...thanks to my forum friends.
This forum is wonderfull!... service took 50 minutes and cost was 45 dollares.
I have to thank all the friends that came to this thread to help me.
Very good help you all gave me, and i made use of your informations
The main wire, that bring the electricity to the thermal break in fuses,
Was find too much hot, conection was bad, and some rust and resistance
Was appearing there.... wire was substituted from that place to the street
Consumption meters./
One room had the wires inverted, so, electronics lamps did not worked fine
And many was there, burned to my examination (9 lamps)
The main room had bad connections to the lamp socket.
All those things were fixed and the 9 lamps lost, as consequence of those
Defects were paid, in cash, immediatelly.
I thank you all for the help gave to me...problem found solution, and the forum
Produced one more real utility for us... the help i received was the one i used
There.
I thank you all, without any exception, the ones that wrote here, and the ones that
Had interest, but unfortunatelly, couldn’t help me...the ones that visited and had
The atention to read my ask for help.
As the problem do not exist anymore, ... depending on me...the thread can go to
Archive... as it will naturally after you all read my thanks.
Thank you
Carlos Eugênio
There.
Thank you
Carlos Eugênio
- Electronic Lamps, electricity, i need help, lamps burning, needing procedure
