Hi all,
To monitor the dual power rails for my HP amp , I made a simple under and over
voltage detector , which switches off the power (and relay) , and gives an indication of what went wrong.
It works as it should , BUT I noticed when doing tests that it gets triggered by starting a fluorescent tube lighting or touching inputs just with a test lead.
Grounding the inputs without the 47k resistors or connecting the inputs with other
HCmos outputs , no problem , but the problem is now also on the optocoupler's
transistor side. When the opto transistor is off , again triggered by fluorescent tube
lighting starter.
Will encasing it in an Aluminium casing solve this ?
Now I made lots of Cmos devices , never had this problem , but now I live in a
electrosmog environment , with lots of badly laid , overhead power wires and a
nearby WiFi transmitter. I had an computer mouse that always switched off when
starting the fluorescent tube lighting. Pulling the USB out and back in , restarted it.
Here are my options :
A RC filter after the HC132 to filter out the glitches. Effective , but I don't want a
big delay and if the C is too big , there is no room for a diode to protect the Hcmos
IC. (How big , or how long are glitches caused by fluorescent tube starting ?)
Or at the opto side = the HC 132's input . Again a cap , but not too big that it can
destroy the opto or the cmos input.
I can't go for lower resistors , because of battery power and it would change the
switching levels.
Yes I can experiment , but i've made a very small pcb with all smd's , which makes
it very difficult and big chance of the copper of the pcb coming loose when soldering too often and everything around it becoming too hot again.
So I ask here first , for people's experience with this.
Yes it is not strictly "Power supplies" , but is is to monitor de power supply to my
HP amp. That's why I posted it here. Thanks.
lighting starter.
switching levels.
You might find your problem is fixed more simply by putting resistors in parallel with the LEDs in your optos.
So the opto's leak ? I'm not sure that will solve it . It means the voltage level at the HC132 inputs will be between the 0 and the 5V with the noise superimposed on it , it might make it worse like using an cmos inverter as an amplifier.
No - its not the optos that leak, its the zeners. There's no telling what current they might pass below their zener voltage - the zener voltage is defined at 1mA minimum normally. They also have capacitance in parallel which might be enough to give you a spurious pulse - especially with your 75k load resistors on the opto outputs.
These are very sharp zeners , at 10 to 100 uA they are already at their voltage , no need for 1 mA or more . Note that the zener side doesn't always have a voltage . On standby , the monitoring circuit is powered up , but the 2 times 2x15V of the amp are 0V so the zeners and optoLED have no current. Glitches like the fluorescent tube starter , trigger the indicator flipflops with or without the zener/optoLED side having power, luckily the reset D-flipflop is not triggered on standby other wise I couldn't put the circuit on.
So it's a good sugestion , but I'm sure it's not spurious noise on the zener .
I've not come across zeners which are at their voltage at 10uA before, I shall be interested to check them out. What's the part number? If I were you, I'd lower those 75ks.
TZM5239B : 9,1 V zener in Minimelf : 8,99V @ 10uA 9,08V @ 6mA from vishay .
DL5245B 15 V zener also in minimelf : 15,11 V @ 5uA 15,22 @ 2,5 mA.
Others around the same values , because of tolerance. Those 2 were used.
1N4744 : 15 V , 1,3W 14,85V @ 5uA 14,88 V @ 2,4 mA . Lots of zener are like this. Zeners lower than 6,2 V are less sharp , in my experience and testing.
Lowering the 75k , changes the threshold/switch level.
I have another input with 10k , and it has the same problem . It's also on batteries so I need to keep the power down.
> again triggered by fluorescent tube lighting starter.
> an computer mouse that always switched off when starting the fluorescent tube lighting
I've had bad fluorescent starters but that one is the WORST.
Try grounding it with clip-lead. (Do not get killed.)
Try gently taking the fixture to scrap-metal and the tubes to the hazard-waste. LEDs are better, and now cheaper. (Yes they have faults also: I just tossed a "good old" G.E. because I thought it was off; on, but dim.)
^There are 3 of them and they are not mine. I can't replace them . I live in sort of the third world , no grounding wires here.
- Power Supplies
- Electromagnetic noise on CMOS Logic inputs
