Electrolityc Capacitors Footprints
Hi guys, im using Protel to create a few PCBs, but i dont have the right footprints for radial capacitor.
I need the Diameter and Pin Distance of the following caps
1000uf 50v - Diam 16,2mm - Pin 8mm
2200uf 50v -
4700uf 50v - Diam 22,2 mm - Pin 10mm
1000uf 63v -
2200uf 63v -
4700uf 63v - Diam 25,3mm - Pin 11,6mm
i want to use the three values in the same PCB, so ppl can choice the one that they want.
Its for an PSU Design.
THanks in advance.
Go to the web page of a supplier such as Farnell, download the datasheets. Everything you need is available on the web. If not, buy the components and measure them. There's too much variation between brands to answer reliably.
w
