Electrohome Planar SR-2100 stereo receiver with SJ5564 power transistors
I have just acquired an electrohome sr-2100 stereo receiver . the problem is that only one channel is working , I am trying to replace the output power transistors and I cannot find any information on them , this receiver uses the Motorola SJ5564 transistor .
does any one out-there know anything about these transistors !
is there a substitute for the sj5564 ? google searches on them comes up zero .
any help would be greatly appreciated , this is a beautiful receiver and I want it back in 100% working order .
Did you ever got it fixed. That number does not ring a bell. I believe each channel has 2 transistors on the heatsink one would be npn and pnp. What are the other numbers of the transistors? Taking photos would help. I've fixed a few Planar gear before.
I have one of these Planar SR-2100. The amp is quasi complementary or what they call in their brochure "semi complementary".
Most likely MJ 15003 would be good replacements . For what it's worth , this is a very good sounding unit. I could never find any schematic anywhere btw.
Cheers
Reactions: PineappleDave
I've just uploaded SM to hifiengine, should be available shortly.
Any idea on the actual output transistor replacements? Mine has four Motorola, two of which need to be replaced. I couldn't find reference/replacement to 601-34.
Any idea how SJ5564 and the MJ 15003 were selected as match?
Just 45, or does that mean 90? Makes A big difference. If that’s a 45 volt single supply just about any of the old 100W Moto parts would work (even 2N3055), but parts like the 2N587* or 8* are “better” in audio apps - gain tends to be higher than 3055’s. Of course the 15003 will work. If it’s +/-45, they’re probably MJ802’s or 2N5630. In that case you need the 15003.
So, I checked other transistors and output resistors and the only other one that seems off is the bias transistor for right channel - hfe > 700 and ic about 3 which is off from everything else. No idea what a replacement would be.
The really odd thing I don't understand is that after testing things and with the two power transistors pulled, I powered on with DBT and no fuse popped from shorted outputs as expected. However, when I plugged in headphones to see what the issue with tuner was, I had sound (static) from both channels. I plugged into the aux and sound from both. Checked for DC on speaker outs, was fine, so hooked up speakers. I have sound from both speakers. I don't understand how things are working. Any ideas?
FYI - great news! The schematic part that I was missing is available in AK database along with part list.
The transistor for bias circuit I am looking for is a small signal transistor.
And the voltages on schematic match what I measured on transistor.
I think I can figure out a replacement, but recommendations are welcomed.
