hi I just picked up an older EV 12 channel mixer and It would be really nice if I could put a mute switch on each channel. What would be the best way to go about this without getting any pops when un-muting? thanks anyone
Be really helpful if you could identify the mixer so we might look at a schematic.
Does it have phantom, and if so do you use phantom?
re electro voice mixer model
hi the mixer is an ev5212 series two, it has phantom power and I would be using it.thanks
http://archives.telex.com/archives/EV/Mixers/Service Manuals/52 series Service Manual.pdf
Series II
http://archives.telex.com/archives/EV/Mixers/Service Manuals/52 Series II Service Manual.pdf
http://archives.telex.com/archives/EV/Mixers/Owners Manuals/52 Series II Owners Manual.pdf
I would put it below the Pan pot left of the LED.
Series II
re ev-5212
Thanks for the info. would I be using a spst push on push off or something else. would this create a pop when turned on. I'm not quite sure where I would wire it in the circuit.Thanks
I would put it after the fader. You get a pop when you have a sudden change in level, namely switching when the signal is not done at zero crossing. You need to reduce the speed of the level shift so using the fader's resistance helps.
Mind you it is almost impossible to get silent switching with mechanical switches, usually it is done through electronic means.
- Live Sound
- Instruments and Amps
- electro voice mixer
